Sponsored by: CARiD
engine rebuilding rotary vs. piston
Old Jul 17, 2003 | 08:22 AM
charger759's Avatar
Newbie
which is easier to rebuild in your guys' opinion, im new to this rotary stuff. just doing some research, feel free to elaborate on whatever you think i need to know.
thanks
Old Jul 17, 2003 | 05:41 PM
Project84's Avatar
Open up! Search Warrant!
I think the rotary is easier.
Old Jul 18, 2003 | 12:26 AM
kyle@insight's Avatar
Dont like it? I dont care
I personally think the piston motor is easier because of the larger amount of knowledge out there. Jim bob doesn't exactly rebuild a rotary in his backyard much like he would a chevy smallblock. Piston motors are what I was raised on so I'd be more familiar with those.
Old Jul 18, 2003 | 04:51 PM
D3rELiC's Avatar
what about cost, if no pistons are blown, and neither the rotors
Old Jul 18, 2003 | 07:14 PM
chairchild's Avatar
50mpg - oooooh yeah!
rotaries would cost the most, due to the cost of the gaskets (not a lot of aftermarket companies would make them - you'd mainly have to get dealer ones)
But how many moving bits do rotary engines have to go wrong?
# x2 Rotors
# eccentric driveshaft
now compare that to a standard 4cl 8v piston jobbie:
# x4 pistons
# x4 camrods
# driveshaft
# cam
# x8 valves
# x8 valve springs
# and all the other timing stuff
a rotary has 3 main bits to go wrong when taking it apart, a piston has more than 26 that can either be bent, broken, or put in wrong.
So if nothing need replacing, and you have a full set of gaskets, I would say the rotary would be the easiest to rebuild
Old Jul 19, 2003 | 08:31 AM
Louis M's Avatar
On the Racing Beat website, it says:
Rebuild Kit 93-95 Turbo
Part Number: 30017
Retail Price: $1,360.00
Old Jul 22, 2003 | 05:17 AM
peejay's Avatar
Old [Sch|F]ool
Rotaries are easier (less measuring) but piston engines are cheaper. You could buy all of the parts needed to do a proper rebuild on many boingers for less than the cost of a single rotor housing.
I was asked recently to rebuild an engine for someone. I quoted an absurdly low labor price, because I felt bad about the parts cost. $1100 for for the hard seals and gasket set. We ain't even bought new housings yet ($500 each, should use two) or rotors (at least one is bad, another $500 or so each). It'd be cheaper to buy a complete running RX-7 and put its engine in the car, then part out the rest. (Or let weeds and small trees grow through it in the backyard, depending on your neighborhood and/or the tolerance of other people in your household)
Economics sucks, don't it.
I should specify that the cost problem isn't due to it being a rotary, it's due to Mazda's grab-your-ankles pricing strategy for parts. Talk to old timers, many of 'em will tell you about how prices for engine parts went up about TENFOLD, two-odd decades ago. They haven't been getting lower, either.
ncds_fc
Aug 15, 2015 10:06 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
