A/c, Press It Car Dies Help!!!1
Old Sep 13, 2001 | 02:49 PM
jmseven's Avatar
Asset is Wealth
I can't use my A/C. I press the button on the logicon, and the engine dies. Does anyone know what the hell is going on?????
Old Sep 13, 2001 | 09:40 PM
Keith's Avatar
I would suggest that you first eliminate the obvious. Have someone in the car press the button while you are watching the A/C pulley. If the entire pulley suddenly stops, stalling the engine, your compressor has seized. You will need to replace it and flush out and recharge the system. If not, look for an electrical short on the clutch wire.
Irv, Keith's dad
Old Sep 14, 2001 | 10:37 AM
SpeedRacer's Avatar
Formula Mazda Driver
Is your engine only stalling when idling with the AC on? If its just an idle problem with AC on than its probably just your BAC..you can try cleaning on the contact points on the electrical connectors...or you can take a DMM or Ohm meter and measure the resistance across the contact points..Its should be no higher than 12ohms I believe..check your haynes or mazda service manual to be sure.
Old Sep 14, 2001 | 10:42 AM
jmseven's Avatar
Asset is Wealth
BAC? Where can I find it? I don't have manual.
Old Sep 14, 2001 | 12:01 PM
SpeedRacer's Avatar
Ok, first of the BAC is your Bypass Air Control Valve..basically it is supposed to allow your car to idle when you turn on your lights, AC or anything that draws power from your car. If you pop your hood, it is going to be on the passenger side of your engine. It is right above the ACV(Air Control Valve) It is a horizontally shaped cylinder looking thing about 4 inches long. Maybe somebody has a pic they could post? You should see an electrical connector going into it. It is pretty high up, it should be plainly visible if you are look at the engine from the passenger side fender You should DEFINENTLY get a haynes manual at the very least. They cost about $12.00 and are invaluable for working on our cars(not as good as the mazda service manual, but those are over $100 so most of us don't have those). Good luck.
Old Sep 14, 2001 | 12:19 PM
FlyGuy2000's Avatar
here's the pic of a 2nd gen BAC
http://www.rhichome.bnl.gov/People/shrey/images/bac.jpg
Old Sep 14, 2001 | 12:31 PM
SpeedRacer's Avatar
Oh yeah...on 86-88 models(like in that picture) the BAC is on the driver said..on 89-91 models it is on the passenger side. So if you have an 89-91 it will be a little harder to find, but at least now you know what it looks like.
Old Sep 14, 2001 | 12:47 PM
jmseven's Avatar
Asset is Wealth
Ah...I remember that unit....it equalizes the manifold pressure.
Thats right....I will check it this weekend....hopefully thats it...
Thanks everyone!!!!!
astrum
24
Nov 15, 2017 08:44 AM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
smikels
Aug 18, 2015 01:26 PM
