Is it BETTER for a TII if it runs COLD all the time?
Old Sep 13, 2001 | 02:46 AM
ROSHX7's Avatar
Unhappy Is it BETTER for a TII if it runs COLD all the time?
I just installed a new fan clutch and now my TII runs super cool. Is that a good thing? The cooler the better? I do run high boost all the time...should i be concerned?
Old Sep 13, 2001 | 03:04 AM
The Ace's Avatar
Greek Power
Question
What do you mean "super cool" ? What's the reading on the temp gauge ? Of course its better to run cooler than hotter. And how much did the new clutch cost ?
Old Sep 13, 2001 | 03:15 AM
ROSHX7's Avatar
Smile
My TEMP gauge never worked properly before, I'm not really sure. All I know is that it read between 1/4 & 1/2 level before when the car was fully hot. Now after getting the new fan put in, it never goes over 1/4, even a tad lower and stays there when the car is fully HOT. Even after a hard run, I open the hood and feel the coolant lines and intake manifold and its a lot cooler then before...the new fan blows pretty hard.
Old Sep 13, 2001 | 04:01 AM
ralph f cooke's Avatar
The clutch is meant to allow the fan to 'freewheel' when the temperature is low enough, and to 'engage' when higher. I would not expect the fan to run continuously at full speed.
On my TII when I start the car the fan comes on at full speed for a few seconds, which is very obvious by the noise level, and then drops to a much lower speed. The only time I would expect to hear the fan running at full speed would be in either heavy traffic, or after a high speed run.
The problem with having the fan running at full power is the drag on the engine - which could be as much as 4~5 HP.
sherff
Feb 24, 2019 12:09 PM
ncds_fc
Aug 15, 2015 10:06 AM
ashleymiche
Aug 14, 2015 12:59 PM
Wolf_
Aug 11, 2015 04:23 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
