Sponsored by: CARiD
fd idleing at 4000 rpms, help!!!
Old Jul 1, 2003 | 12:37 AM
bladz311's Avatar
I just got my manifold polished to match my greddy elbow and greddy fmic. I installed all 3 and when I started the car, it idled at 4000 rmps. Did I mess up some of the vac lines on the upper manifold or something? I thought I put them back in the same place. What would cause this? Thanks for your help! BTW, this is on a 1993 rx7.
Old Jul 1, 2003 | 07:03 AM
Sinful7's Avatar
It could be your idle adjust screw got turned by the buffing wheel when you had it polished, so just play with that and see if it idles better.
Old Jul 1, 2003 | 08:54 AM
Cosmo Donk's Avatar
Queer
Yah, just check the idle adjustment pieces. Throttle cable, throttle screw, vacuum hoses, etc.. Unhook the throttle cable and see if it will lower the idle.
Old Jul 1, 2003 | 10:45 AM
bladz311's Avatar
I checked the throttle cable, it seemed good. Could any of the vacume lines cause this?
Old Jul 2, 2003 | 02:01 AM
bladz311's Avatar
I figured it out!! The gasket between the throttle body and the manifold is cracked and was leaking. I put my hand over it, and my rpm's dropped!
Old Jul 2, 2003 | 08:58 AM
Cosmo Donk's Avatar
Queer
There ya have it Thanks for posting the fix!
24seven_dada
20
Nov 10, 2018 12:03 PM
alexdimen
20
Oct 23, 2015 01:50 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
