Oil Leaks?
Old Sep 10, 2001 | 12:12 PM
SleepR1's Avatar
Oil Leaks?
How many of you have FDs that leak oil?
What are the common problem areas?
Old Sep 10, 2001 | 01:00 PM
jr's Avatar
jr
I've got a leak at the rear main seal right now, it's not very bad so I'm just leaving it alone till I get a rebuild. The 3 most common leaks are:
Rear Main Seal - $50 part, about $300 to install (have to pull tranny)
Oil Pan Gasket - $? part, about $500 installed at most shops.
Turbos - $1K+, if the turbos are leaking badly they may need to be rebuilt or replaced, figure about $1K for a rebuild or $3K+ to replace.
Old Sep 10, 2001 | 01:15 PM
SleepR1's Avatar
I've been chasing an oil leak for a couple of years now. Here the parts I've had done replaced:
-leaking oil sending unit
-throttle body intake gasket
-intake elbow rubber gasket
-oil filler neck gasket (crushed)
-oil filter O-Ring gaskets (crushed)
-rear main seal (actually not that bad upon inspection)
-stationary gear seal (hardened and crusty)
-turbo oil return line gaskets (leaking badly).
After all this I still have oil leaking. I'm looking into some oil lines coming from the turbos that run just above the steering rack.
Perhaps, I have leaking turbos? The turbos are still showing good boost pattern (10-8-10), if they are leaking?
Old Sep 10, 2001 | 01:27 PM
jr's Avatar
jr
Perhaps, do you have an excessive amount of oil in your intake piping? There should be a small amount, but if you have large pools than you might want to explore that avenue. Usually though bad turbos don't "leak" oil onto the ground, they leak oil into the intake system which then gets burned, you'll see excessive exhaust smoke with this. However they might also leak if they are cracked. I can't say for sure though, I've never had that problem.
Old Sep 11, 2001 | 07:40 PM
rx7_lover's Avatar
oil metering pump
have you checked your oil metering pump and lines?
mine is leaking oil (105k miles).
Old Sep 12, 2001 | 12:50 PM
RX7-2JOCK's Avatar
ZZzzzzz...PHshshshssshh
I'm a victim of bad O-rings oil leak..........waiting for a rebuilt
Old Sep 12, 2001 | 01:00 PM
Want2race's Avatar
Bigger and better things
I bet its your oil metering pump o ring!!! It seals it to the block (or parts similiar)
Old Sep 12, 2001 | 01:16 PM
SleepR1's Avatar
Oil Metering Pump and Lines?
No, I haven't had that checked out. I'm having this looked at this Friday. Thanks for the input!
Old Dec 8, 2010 | 11:19 PM
kevin arnold's Avatar
R-POWER
oil return line from the turbo to the front cover, 1 have @ 1971 rx2 with @ 13b re streetport fi turbo, its always leaking oil n that spot 350 to the rear wheels
Old Dec 10, 2010 | 11:34 PM
I have had my rx-7 for 5 years and I have had a small (dime size after it sits for a day or two) leak for 5 years. I have resealed the oil pan twice and i now believe it is the rear seal or the oil metering pump. I had a second gen for 13 years and that thing always had a small leak too. I guess I am just used to it. Kinda like radial aircraft engines-they always leak.
Old Dec 11, 2010 | 12:23 AM
RotaryEvolution's Avatar
Sharp Claws
here's a generic list from most common to least common oil leaks on the S6 that i see:
oil pan left rear corner
oil metering pump body
oil filter pedestal
oil pressure sender unit
rear stationary gear o-ring
rear main seal(they like to grab the -shaft and spin in the stat gear)
front cover gasket
front main seal
Old Dec 11, 2010 | 07:13 AM
Banzai-Racing's Avatar
Rotary Specialists
This thread is over 9 years old, I hope the leak has been fixed by now. .
Old Dec 11, 2010 | 10:16 PM
oil filter pedestal
front cover gasket
front main seal
Don't forget the oil level sending unit
rotor_veux
Sep 3, 2015 07:10 PM
sypath
Aug 16, 2015 12:06 AM
