stock rims
Old Jun 25, 2003 | 06:18 PM
mcinnes's Avatar
NO ROTOR NO MOTOR
Question stock rims
how do you clean the stock rims? the car was in a joint yard for a couple years and the rims have like a white grim on them, and i tried most rims cleaners
Old Jun 25, 2003 | 06:21 PM
ioTus's Avatar
'84 5-letter
Is it similar to a spider web effect? if so, its pretty much impossible to "repair". the only fix i know of is polishing the wheels down to shiney metal. This makes them look chrome.
Hope this helps,,
Old Jun 25, 2003 | 06:25 PM
mcinnes's Avatar
NO ROTOR NO MOTOR
ill give that a try
Old Jun 25, 2003 | 08:18 PM
82transam's Avatar
Never Follow
use some paint stipper or mild acid to get all the paint and clearcoat off then polish them a bit and repaint.
Old Jun 25, 2003 | 10:03 PM
calvin's Avatar
Some of the paint manufacturers (Dupont and Ditzler) make a wheel clearcoat refinishing kit. Basically is is a special stripper that will strip the old clearcoat off and some chemicals to pre-treat them, and then new clearcoat. These kits are not all that expensive. Check out your local automotive paint suppliers for this.
Akaviri
Sep 9, 2015 03:56 PM
Barrman
Sep 8, 2015 03:25 PM
