Dead compressor... or so it seems?
Old Jun 17, 2003 | 03:19 PM
FuLLsMoKe's Avatar
"By the beard of Zeus!"
when i drove to school today, i noticed that when i turned on the a/c the air did not get cooler... i decided to pull over and check under the hood--which everything seemed fine. when you turn on the a/c, the clutch of the compressor does not engage (so it seems) thus no a/c for me. since i am at school right now, and i have a 1 hour break, what simple things (since i have almost no tools with me) can i do to try to fix my compressor or see what is wrong with it?
Old Jun 17, 2003 | 03:22 PM
Felix Wankel's Avatar
Super Newbie
turn the clutch in the middle by hand, if it turns you are probably out of/really low on freon. Some oil change places service A/C systems cheap.
Old Jun 17, 2003 | 03:25 PM
FuLLsMoKe's Avatar
yesterday the a/c was fine... and i changed the freon about a year ago
Old Jun 17, 2003 | 03:27 PM
Super Newbie
unplug the green (I think) wire on the compressor and stick it to +12V with the AC on. The clutch should engage and then you can see if the air is cold.
Old Jun 17, 2003 | 03:33 PM
FuLLsMoKe's Avatar
right now it's raining and i don't wanna go out... but if i do that with the green wire and it does engage, what's my problem? is it an electrical problem?
Old Jun 17, 2003 | 03:37 PM
Super Newbie
may be the relay or the button on the dash. (I don't remember how the wiring goes)
Old Jun 17, 2003 | 03:57 PM
RoyFifo's Avatar
The connectors on my pressure valve came loose the other day and caused mine to stop working.
You should be able to pull the rubber cover infront of the radiator and get to the low pressure switch to check.
You can also bypass the switch at the relay.
The relay should be the one closest to your Hot Start Assist motor. There is a blue wire comming off of it that goes foward to the pressure switch, them back into the cabin.
Mine has spade disconnects, just unplug them from the normal position, and plug the two remaining short lines together (from relay, into cabin (joins with yellow wire into a wrapped harness)) and you will have bypassed the pressure switch.
Or at least that's how it's setup on my 82.
Old Jun 17, 2003 | 04:20 PM
Cody's Avatar
SKELETOR!
I don't understand why my A/C stopped working. I mean, all I did was cut the belt off. These rotaries are so confusing.
Old Jun 18, 2003 | 01:21 AM
Heath's Avatar
MAGNUM SE7EN
I have all the A/C components for sale if you need anything.
Old Jun 18, 2003 | 04:05 AM
AdrenalifeRX7's Avatar
Are you gonna shift?!
ditto
Old Jun 18, 2003 | 08:31 AM
FuLLsMoKe's Avatar
hehe... sorry guys, i've got 2 parts cars and both have working a/c
but i'm only using them as last ditch efforts since i believe my compressor is still good, just that i have some electrical problems.
R.O.D
34
Jan 6, 2016 12:09 AM
imitek
Oct 18, 2015 03:35 PM
Thor 18
Sep 28, 2015 07:35 PM
