Tranny drain bolt which way does it turn?
Old Jun 15, 2003 | 07:20 PM
O 16581 72452 5's Avatar
The infamous number guy!
I'm sick of stripping it out trying to figure out whiich way it turns, if the wreck is pointed towards my rear diff do i pull it towards the drivers side or push towards the pass?
Old Jun 15, 2003 | 07:28 PM
Pele's Avatar
Right near Malloy
Drivers side man... It's a normal bolt. Lefty loosey, rightie tightie...
Or as I was taught, Imagine it as the center of a clock. Putting the bolt in is forwards on the clock, out is reverse.
However... You may wanna loosten the filler plug first... What happens if you drain it and find out that the filler plug is stuck closed. Prepare man... Prepare.
Old Jun 15, 2003 | 07:32 PM
I already took out the fill bolt, it was easy, i just now got the drain bolt out, i didn't know which way to look at the bolt to loosen it... the way i was looking at it going the opposite way was the right way.
Old Jun 15, 2003 | 09:54 PM
vipernicus42's Avatar
Rotoholic Moderookie
**** man, I'm having *exactly* the same problem. Filler bolt came out no prob, but the damn drain bolt is like spot welded in there or something. I knew the "rightie tightie, lefty loosie" thing, so I know I've been pulling the proper direction, but the damn thing won't budge... a whole bunch of liquid wrench, WD-40, and a big honkin' wratchet with a six-point socket of almost exactly the right size and it won't frigging budge!
If anyone has any suggestions I'd love to hear 'em. Is it possible that some idiot DID weld it on? Or is this a common problem? The bolt is so low-profile that it's often hard to get a good grip on and I'm sure I'm stripping it a bit... but what else can I do?!?
Jon
Old Jun 15, 2003 | 10:04 PM
RacerX7fb's Avatar
paradox
Pipe wrench time!
Old Jun 15, 2003 | 10:05 PM
I used a cresent wrech and just pushed the **** out of it and it broke loose finally.
Old Jun 15, 2003 | 10:07 PM
cresent wrench? what exactly is that? Like a box-end wrench?
And exactly what size did you use? I've been having a hard time finding out the size of the bolt. 24mm is too big, 22 is too small, I found an imperial one that fit not too bad... is it a 23mm or is it imperial?
Jon
Old Jun 15, 2003 | 10:09 PM
wwilliam54's Avatar
it WILL run
the odd MM sizes are = to imperial sizes
Old Jun 15, 2003 | 10:10 PM
Cresent wrech... it's adjustable, or maybe it's called adjustable wrech, not a cresent wrech?
Old Jun 15, 2003 | 11:25 PM
Cody's Avatar
SKELETOR!
I think they're called a spanner wrench in those crazy places that aren't in the U.S.
Old Jun 16, 2003 | 12:11 AM
Pele's Avatar
Right near Malloy
Crescent wrench:
Jon
No such size... It's adjustable. Personally I think it's a bit risky using one of those or an open ended wrench on a bolt that's low profile like that, especially when it's really tight... Too much risk of rounding it off... Box ended... Usually when it's tight, I use a combonation wrench. Put the box end on the bolt, then put another, slightly larger size box end wrench on the open end... (Old mechanics trick... Learned it as... Duh, a mechanic... It's kinda hard to describe, but as soon as you see it, it's cool.) It allows you to double your leverage of the wrenches.
Or just use a pipe.
Old Jun 16, 2003 | 12:12 AM
Pele's Avatar
Right near Malloy
I thought a spanner was an open ended wrench.
Old Jun 16, 2003 | 12:21 AM
Felix Wankel's Avatar
Super Newbie
Crescent is a brand name, like Channel Lock or Vice Grips. The correct name is adjustable wrench.
A spanner is one of those goofy looking C shaped wrenches.
Old Jun 16, 2003 | 12:26 AM
Pele's Avatar
Right near Malloy
Well, do you use a Xerox machine or a Photo Copy machine? Is it Scotch tape or Cellophane Tape? Do you blow your nose on a Kleenex, or tissue?
Brands have come into acceptance in our consumer oriented world... Unfortunately...
Yeah... So how many more can you think of? Just for the record, Proper names for Vice Grips are Locking Pliers, and Channel Locks are tongue and groove pliers.
Old Jun 16, 2003 | 04:37 AM
Oh God, the idea of using a cresent wrench to do that bolt would be horrifying.. Alright, so yeah I tried that two days ago already. My wrench doesn't seem to tighten up very well, so all it ended up doing was "readjusting" to slip off as I turned... Useless piece of crap...
For the guys who haven't used a cresent wrench, what size is that bolt? Is it imperial or metric? I know that odd metric sizes mean imperial, but as I said, it *could* be a 23mm, I just haven't yet found a part store that has a 23mm wrench in stock!
Jon
Old Jun 16, 2003 | 06:17 AM
mwpayne's Avatar
Admitted 'rexaholic'
I just did this, and it was either the 5/16 or 7/8 socket I used. It wasn't metric for sure. I used also a BIG socket wrench and PUSHED it towards the rear of the car (counterclockwise).
Old Jun 16, 2003 | 11:40 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
Do they call 'em a "croissant" wrench in France?
Old Jun 16, 2003 | 04:20 PM
RotorMotorDriver's Avatar
Seven Is Coming
I used an air ratchet, came right off .
~T.J.
Old Jun 17, 2003 | 09:07 AM
bliffle's Avatar
Might be an american size! Use a six point, not 12 point, to avoid rounding off. Maybe grind off 1/32 from socket to get rid of chamfer inside socket.
B
Old Jun 17, 2003 | 09:50 AM
anthrax's Avatar
Heck Yes!
I just did this on the week end.
The Plug turns Clock Wise in and Counter Clock wise out.
I used a 24mm Socket, but 15/16" will also work.
The Fill hole plug is 15mm Clock wise in and Counter Clock wise out.
A 3/8" Drive will fit in the square hole in both plugs in the Rear End.
These are also Clock wise in counter clock wise out
Old Jun 17, 2003 | 03:43 PM
I tried a 7/8" wrench... too small... I tried a 24mm wrench, too big... I tried a 22mm wrench, too small... Local parts store doesn't carry a 23mm wrench, can't try it. Found some un-marked six-point socket that I'm sure is imperial, and it fit *okay*, but not great. Still strips the ******* thing. Grrr....
I know the direction to take the plug out, it's just really siezed in there.
Jon
FD7KiD
15
Feb 26, 2021 10:12 PM
Rotospectre
Mar 28, 2018 03:33 PM
alphawolff
Nov 17, 2015 05:57 PM
FD7KiD
Aug 17, 2015 11:50 PM
