NEED HELP FAST!...solenoid question
Old Sep 7, 2001 | 12:50 AM
Mikey's Avatar
okay...i have FINALLY got the hose rack off...but quess what...i too broke a nipple it is the double throttle control one...i read from other post that i don't really need the egr solenoid. so i was thinking i could just use the broke one as the egr...since it doesn't really matter from what i have read. but if i was to just do without the egr solenoid...what do i do about the hoses that would plug into it...just leave them open, or block them off.
thanks,
mike
Old Sep 7, 2001 | 09:55 AM
spooledUP7's Avatar
There and back again
Yes, you can use the EGR valve solenoid. Put a plug on both the metal tubes after you remove the solenoid. Make sure that you secure the plugs well.
You can leave the EGR in place. It is normally closed, or you can buy a block off plate.
Old Sep 7, 2001 | 01:30 PM
Mikey's Avatar
okay...so i blocked the two metal nipples (one leading to the manifold and the other leading to the egr valve. now what do i do with solenoid itslef? not plug it in to the computer...or do i plug all three of the nipples on it (one going to the manifold, one to the egr valve, and the filter?)
thanks again,
mike
Old Sep 7, 2001 | 03:27 PM
Mikey's Avatar
bump. anybody...PLEASE
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
TwentyDW
Sep 2, 2015 06:42 PM
