nipples on front turbo popped out...
Old Jun 11, 2003 | 01:15 AM
COsborne's Avatar
My Custom Title > Your's
I dont know if this is stock or not... I was going down the road at 10 psi and all of a sudden I hear a whoosh and it hits 20 psi and I let off right away. I pulled over and checked it out. The nipple that holds the lines that go to the wastegate actuators popped out. I dont know how in the hell this thing is supposed to stay in the turbo.... Has this happened to anyone else? Im mega confused.
Old Jun 11, 2003 | 02:06 AM
duboisr's Avatar
They are pressed it , you may need to epoxy them back .
Old Jun 11, 2003 | 02:32 AM
COsborne's Avatar
I assume youre talking about the same thing... here it is
Old Jun 11, 2003 | 03:36 AM
duboisr's Avatar
Yes on the pri turbo only. Garfinkle pulled his by twisting and pulling. He threaded the hole and put a bolt in it to close it. He drilled a hole in the firewall side of the uim and pressed the f shaped fitting in the hole with epoxy . All of his vacuum lines are hidden from view, to clean .
Old Jun 11, 2003 | 09:05 AM
lerch32's Avatar
It has happened to me as well. I just carefully jb welled it into place.
Old Jun 11, 2003 | 09:22 AM
apexkw's Avatar
in slow, out fast!
heh heh heh.... you said nipples
Old Jun 11, 2003 | 10:09 AM
COsborne's Avatar
well thats that.... glad I put that supra fuel pump in
FD7KiD
15
Feb 26, 2021 10:12 PM
dkwasherexd
May 27, 2017 04:51 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
FD7KiD
Aug 17, 2015 11:50 PM
