carbon fiber drive shat
Old Jun 10, 2003 | 12:32 AM
fcfdfan's Avatar
Reverse Engineer
ACT in Huntington Beach, CA, can help you out. But are you sure that's the mod you need if your sig says "not enough power"?
Old Jun 10, 2003 | 12:33 AM
93blackrx's Avatar
I believe it is similar to a light weight flywheel, I'm not sure how much of a difference it makes though. I thought I saw then at www.rx7.com and they seemed outragously expensive to me. Not too high on my priorites right now.
Matt
Old Jun 10, 2003 | 01:10 AM
HedgeHog's Avatar
Rotary Poseur
It's actually ACPT not ACT. www.acpt.com
Our d/s is quite short so the weight savings isnt that huge. I never weighed mine but just holding it felt only a small weight savings. However, power tranmission seems to be smoother...or mebbe i'm just imagining it.
Old Jun 10, 2003 | 01:13 AM
GoRacer's Avatar
Speed Mach Go Go Go
I thought MazdaSpeed offered one? Doesn't the RX-8 come with one?
Old Jun 10, 2003 | 01:14 AM
DaiOni's Avatar
Wankler
there are a handful of japanese manufacturers who make them. Need a healthy wallet though.
Old Jun 10, 2003 | 02:20 AM
maxcooper's Avatar
WWFSMD
It would probably be better for you to get a "normal" replacement. Mazdatrix sells ones with replaceable u-joints for less than the factory part.
-Max
Old Jun 10, 2003 | 02:59 AM
r0gu3's Avatar
Boostless FD
A lot less drivetrain loss, gain some HP at the wheels there.
Old Jun 10, 2003 | 03:24 AM
maxcooper's Avatar
WWFSMD
I don't think it significantly reduces the inertial losses. The stock part is not much heavier and the diameter is pretty small when compared to a flywheel for instance. It also spins slower than the flywheel since it is after the transmission, so that further reduces its inertial contribution relative to a flywheel. I am sure it makes some difference (it has to -- it is lighter), but it is unlikely to be a very significant difference. It should reduce drivetrain shock, but the CF driveshaft is not a big bang-for-the-buck mod, so it makes sense to put it off until you have most of the other mods that give a bigger boost for the money.
-Max
Old Jun 10, 2003 | 03:52 AM
r0gu3's Avatar
Boostless FD
I was kidding, hence the smiley.
Old Jun 10, 2003 | 08:12 AM
DamonB's Avatar
Forgot about that one. The stock driveshaft is so danged light I don't see spending all that dough. Unless you've got a tube frame carbon bodied endurance racer I see no need to spend that far for so little gain.
Snoopy FD
Dec 8, 2015 01:45 PM
