My Tach Stopped Jumping...Finally
Old Jun 9, 2003 | 03:05 AM
RotorMotorDriver's Avatar
Seven Is Coming
Talking My Tach Stopped Jumping...Finally
Well, the other day (almost a week ago)I re-adjusted my timing, and it hasnt jumped yet. I just thought I would share because I was so damn happy after dealing with it for so damn long. It still jumped after cheking wires, replacing plugs, replacing wires, new cap, rotor, swapping ignitors, new coils, everthing in the ignition system. I dont know why it did it, Im just happy its stopped!!
~T.J.
Old Jun 9, 2003 | 03:09 AM
AdrenalifeRX7's Avatar
Are you gonna shift?!
Was your timing advanced or retarded?
Old Jun 9, 2003 | 03:13 AM
Seven Is Coming
I dunno... Sorry .
~T.J.
Old Jun 9, 2003 | 12:35 PM
Jeff20B's Avatar
Lapping = Fapping
Cool!
Old Jun 9, 2003 | 09:14 PM
Seven Is Coming
Yeah, I thought so, lol.
~T.J.
Old Jun 9, 2003 | 09:50 PM
mperformance's Avatar
oops dp
Old Jun 9, 2003 | 09:52 PM
that's temporary it will haunt u again...hahahhaa the gremlin will be back...
j/k
Old Jun 9, 2003 | 09:56 PM
O 16581 72452 5's Avatar
The infamous number guy!
mperformance is right... mine did that then went away on it's own, then came back, now it's gone again.
Old Jun 9, 2003 | 10:02 PM
Seven Is Coming
Great, lol. Oh well, at least I can have some sanity while its gone .
~T.J.
Old Jun 9, 2003 | 11:00 PM
Jeff20B's Avatar
Lapping = Fapping
Mine jumped when I was messing with wires under the hood. I jiggled them again 'till it stopped. I've been lucky so far.
Old Jun 9, 2003 | 11:41 PM
Seven Is Coming
Haha, this from the DLIDFIS wizard, lol.
~T.J.
Old Jun 10, 2003 | 02:44 AM
Jeff20B's Avatar
Lapping = Fapping
Actually, it was when I was trying my 20B dizzy with only one pickup hooked to both Leading ignitors. The other two (L2 and L3) were firing into the air so I could still get an accurate timing light on my 120 and 240 degree marked pulley. My Trailing circuit was disconnected for this test so I simply plugged the tach signal wire into one of my Leading coils. This is where the jumpy tach started. I just jiggled some wires and the jumpyness went away. Then it came back. I then plugged it onto the other Leading coil and that solved it.
Old Jun 10, 2003 | 04:08 AM
Seven Is Coming
Yeah, I had my tach running on a leading coil one time, and it sure does act funny there...
~T.J.
Old Jun 10, 2003 | 07:01 AM
timmya2's Avatar
hey mine is jumping now!!
wat do i do?
Old Jun 10, 2003 | 11:41 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
Hmmm, I just reconnected the vacuum advance line to my distributor and my tach started jumping a little bit.
Interesting...
Old Jun 10, 2003 | 01:06 PM
Jeff20B's Avatar
Lapping = Fapping
If I were to reconnect my vacuum lines, do I need to reset my timing? Something is telling me not to, because above 4k RPM, there's no vacuum anyway. I've just never run with vacuum hooked up. When I upgrade to an electronic dizzy in my points vehicles, I just plug the vacuum nipple on the carb or manifold.
Old Jun 10, 2003 | 05:40 PM
Wankelguy's Avatar
Whoa, who told you there's no vacuum above 4000 rpm? If that were true, the vacuum operated secondaries would never open. You may have to reset your timing after reconnecting the vacuum advance line. I did notice an increase in low/mid power after reconnecting my vacuum advance, but I haven't reset the timing yet.
Old Jun 10, 2003 | 05:48 PM
GT1's Avatar
GT1
Does yours jump alot more when you have a strong current draw on the electrical system?? Mine jumped alot at idle, but only when I was taxing the battery with full blower, rear defroster, and headlights.
Old Jun 10, 2003 | 08:56 PM
Seven Is Coming
Theres just no more vacuum advance, hows that?
~T.J.
Old Jun 10, 2003 | 11:52 PM
Jeff20B's Avatar
Lapping = Fapping
Yeah, interesting. I may try hooking vacuum advance up.
SSpyderX
1st Gen General Discussion
Sep 29, 2015 04:37 PM
Thor 18
Sep 28, 2015 07:35 PM
Casual_John
Canadian Forum
Sep 26, 2015 01:47 PM
subeone
Sep 24, 2015 09:58 PM
