Gjorde nåt väldigt dumt igår
That's swedish
Anyways i need alittle help with something im unsure of.
I was gonna drive to work yeterday but changed my mind since it started raining, so i drove the car back into the garage and shut it off. Today it wouldnt start and i was sure that it was flooded and i was right, i took the sparkplugs out and cleaned them, unflooded the engine and put the plugs back in. The car didnt wanna start now either, no ignition at all. it turned but no ignition.
My question is: Should i have put ATF oil into the engine aswell? I thought it wouldnt be necessary cause i should have compression right?
I've searched but there's so many quesions about this and it's hard to find anything useful, plus im surfing with a modem so it takes so f-ucking long time to search.
That's swedish
Originally posted by RotaryRocket101
I wish I could help u bro,sorry.
Try this: hold down the gas pedal to the floor and crank the engine over. This shuts off the fuel injectors and allows the maximum amount of air into the engine. It's sort of a built-in unflooding procedure.
don't worry about me , if there's no need for the ATF when flooding then i just need new plugs. But i dont wanna buy new plugs if it isnt necessary. I can't buy plugs until tuesday either and then they won't come home until friday, so if ATF would work id really like to know.
they ATF will work even though the deflooding method didn't
If you are sequential instead of taking everything off see if you can just take the 4 bolts off of the end of the uim and then pry it up enough to pour some atf in there with a funnel or anything that will work. Try a couple ounces that should do it. I've never had a problem with the car flooding after turning it on and off. I always move my car from outside into the garage when its fully cold.
Trending Topics
atf helps because the extra gas washes away the oil and carbon inside the rotor housing. The oil and carbon helps the apex seal, seal better. the atf fluid helps improve the seal allowing more compression, allowing the car to start easier.
This is most often useful in cars with older motors where compression is not as great as it could be to begin with. The atf fluid also helps to start motors that have sat for a long time and get carbon lock.
i believe the other antiflooding methods are better for you. But if they dont work then it cant hurt to try some atf.
You can pull the fuse for the fuel pump and crank it for a while to clean out some gas. Then replace fuse and try again.
If the plugs are really wet you will have to dry them off. Pull them out....or you could try to let it sit overnight and maybe dry off themselves.
Tobias: If you replace the plugs it will probably start without the ATF. The ATF trick is usually used as a last resort.
You can drain some oil or ATF into the nipples on the UIM where people commonly hook up a boost gauge. That will get some oil into the chamber to assist in sealing without having to take anything apart. If you can get one rotor firing, the other one should start to fire as soon as the engine is idling.
-Max
-Max
-Max
-Max
Why not try the old push start? Worked for me. Just get it going, either down a hill, or in my case, being pushed by a ford Aerostar with a couch cushion in between, step on the clutch, put it in first, and let off the clutch. Sure fire way, and no dissassembly, no ATF. Just make sure the key is in the ignition, and in the "on" position. Good luck man.
When you unflood the engine, remove the plugs while cranking it over with fuel pump relay removed and throttle pedal to the floor. In a stubborn case, do this procedure a few times throughout the day and leave it overnight with the plugs out so all the gas can evaporate.
If you get to the last resort with ATF, try motor oil first.
Once you get it running, check your oil to make sure its not contaminated with too much gas.
Good Luck
Good Luck
Phearthe-Rx7
2nd Generation Non-Technical and pictures
Apr 19, 2009 09:38 AM
EliteShow
SE RX-7 Forum
Jul 17, 2008 04:43 PM
Nat6c
Mar 26, 2006 11:41 AM
