'99 turbos' wastegate size
Old Jun 4, 2003 | 01:51 AM
Is the size of the wastegate on the '99 turbos sufficient to run a midpipe w/boost controller and not have to worry about boost creep, or should I port it before installing?
Old Jun 5, 2003 | 04:03 AM
*bump*
Would really appreciate an answer on this...
Old Jun 5, 2003 | 08:29 AM
I don't think that information is readily available. The 99's do flow ~20% better. Try contacting a J-spec importer, they might know.
Old Jun 5, 2003 | 10:10 AM
redrotorR1's Avatar
LS6 Convert
I run the RS/RZ turbos with a midpipe and use the PFC as my boost control. I have no boost creep issues. But I'm very careful in cold weather (<60F). Each car is different, so there really isn't a bulletproof answer. If you're that concerned with it, then just port it. But I'll warn you that porting may still not prevent boost creep from happening.
Old Jun 5, 2003 | 02:28 PM
Thanks for the reply. I'll just have to be careful and take it easy with the boost control. I'm going to be using a Profec B Spec II.
FD7KiD
15
Feb 26, 2021 10:12 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
FD7KiD
Aug 17, 2015 11:50 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
