can i remove this...
Old Jun 2, 2003 | 05:06 PM
FB II's Avatar
what is it and do i need it? i think it's the shutter valve??? it's in the intake manifold; this isn't the clearest shot. (carb is removed; looking down manifold) thanks,
-zac
Old Jun 2, 2003 | 05:30 PM
O 16581 72452 5's Avatar
The infamous number guy!
I've got one of those too for the bottom set of butterflies on my throttle body...i'm assuming it's probably needed for your secondaries...but i know practically nothing about carbs.
Old Jun 2, 2003 | 05:32 PM
RotorMotorDriver's Avatar
Seven Is Coming
Yeah, thats the shutter valve.
~T.J.
Old Jun 2, 2003 | 07:44 PM
onepointone's Avatar
i say what i want
what does it do? i noticed that on my spare rex when we pulled the motor.
Old Jun 2, 2003 | 07:46 PM
I assume it's vacuum secondaries?
Old Jun 2, 2003 | 08:30 PM
Rx7carl's Avatar
Airflow is my life
Yes its the famous shutter valve. You can remove the external actuator and wire tie the butterfly to stay open. Removing the butterfly is not reccomended. Itll cause an imbalance in the runner sizes. That runner is bigger then the front one if you look at it. Its bigger to compensate for the butterfly.
Whats it for? Its to prevent backfiring on deceleration. Nothing more.
Old Jun 3, 2003 | 06:24 AM
inittab's Avatar
I read your email
iiinteresting.....
I just noticed this "cut-through" between the front primary and secondary runners. What's that all about?
Old Jun 3, 2003 | 01:25 PM
Pedestrian X's Avatar
SpAz!
coincidence, that moajority fo them time and egnines dies it is the rear rotor?
Old Jun 3, 2003 | 01:39 PM
wwilliam54's Avatar
it WILL run
easiest way to fix it
get a '79 intake
Old Jun 3, 2003 | 01:45 PM
FB II's Avatar
WAIT, you mean that isnt supposed to be like that/??????????????? WTF!!!!!! how could that happen?
Old Jun 3, 2003 | 01:52 PM
82transam's Avatar
Never Follow
No its supposed to be like that. Not sure why, but my cars all have that cutout. And yes, that is the shutter valve, if you don't have inspection get rid of it.
Old Jun 3, 2003 | 01:54 PM
AdrenalifeRX7's Avatar
Are you gonna shift?!
You must have small furry Ewoks inside the intake.
Old Jun 3, 2003 | 01:56 PM
FB II's Avatar
so your telling me somehow my intake manifold just got this cut out from somewhere???? hahahah THIS IS CRAZY!!!! ooooorrrr, someone put a bad intake in there before i got it maybe? it's supposed to be flat i guess huh? i am so lost.
Old Jun 3, 2003 | 02:03 PM
nosajwrx-7's Avatar
Rotax, Rotaries & Turbos
I believe it is supposed to be there!
wwilliam54's Avatar
it WILL run
dont worry they are supposed to be there
mine has one on each side heh
Old Jun 3, 2003 | 02:14 PM
error402's Avatar
#!/sup_mod/üb3rg33k
The cut is there to balance the air/fuel mixture. For example if you got a RB intake and it didn’t have the cut through channel, you would want to get an adaptor that simulates the cut through.
-Error
Old Jun 3, 2003 | 03:17 PM
FB II's Avatar
yea i just talked to rotorsports racing about it too and he was like, "don't worry zach, every 12a i've worked on has it." i'm like, well god damn! hahahaha you guys scared the **** out of me! i'm very sensitive right now LOL!!!! i am picking up my new Nikki thursday, car should run well after that. i'm not 4kin with this rebuild stuff again. thanks guys!
-zac
Old Jun 3, 2003 | 03:57 PM
inittab's Avatar
I read your email
Errr sorry for the confusion... I know it's suppose to be like that I'm just wondering why it was designed by Mazda that way.
Originally posted by inittab
iiinteresting.....
Old Jun 3, 2003 | 05:02 PM
FB II's Avatar
ooooohhhhhhhh, LOL!!!!! damn yea you got me way out of wack in the head. hahahahhaa, WOOWEEE!
-zac
Steelwheelz
Sep 15, 2015 03:22 PM
risingsunroof82
Sep 7, 2015 01:11 PM
