Water Pump Question
Old May 28, 2003 | 04:12 PM
RXTbone's Avatar
Water Pump Question
I've been trying to run down a small cooling leak - changed hoses, etc... I think I've traced it to the water pump. From what I understand, there are two seals, one between the two pump housings, the other between the pump and the engine. Should I pull the housings apart, or is it worth $50 of time and effort to replace the pump itself? Also, what kind of labor time am I looking at?
I've been reading through several threads - is it correct that the damned eccentric shaft goes through the pump?! I'm having heart palpitations...
Thanks for any feedback!
Old May 28, 2003 | 04:28 PM
RacerX7fb's Avatar
paradox
Mind as well get a new pump while you're at it...save yourself the headache of having to do it all over again. The airpump and alternator are mounted onto the waterpump so those have to be removed as well as the fan and pulley for the A/C belt if your car has that. Use new gaskets and a good amount of hylomar when reassembling then torque to specs.
No the eccentric shaft does not go through the pump .. so relax
Old May 28, 2003 | 04:43 PM
RXTbone's Avatar
Whew.... thanks!
FD7KiD
15
Feb 26, 2021 10:12 PM
sherff
Feb 24, 2019 12:09 PM
FD7KiD
Aug 17, 2015 11:50 PM
