Spark Plugs?
Old Sep 3, 2001 | 09:41 PM
rreader's Avatar
Question Spark Plugs?
Has anyone run a GSL-SE 13B with 86 and up 13B plugs (LEADING PLUGS NGK #BUR7EQ & TRAILING PLUGS NGK #BUR9EQ) Does it work? Is it better or worse?
Thanks
Old Sep 4, 2001 | 12:24 AM
Jeff20B's Avatar
Lapping = Fapping
My friend is almost doing that. He has a GSL-SE engine in a rotary truck which is using a modified Nikki carb and manifold with BUR 7 and 9 plugs. It seems to be running fine. It's running a little rich at the moment though, but I think it's because the air filter is kinda dirty. It fires up and runs pretty good.
If you really want to find out for yourself if BUR7(and 9)EQ plugs work better or worse in your engine, go ahead. The stock setup calls for BR9EQ-14. My bro ran his with BR8EQ-14 and I don't think it messed up the engine or anything. They are just one heat range hotter than the 9s.
Old Sep 4, 2001 | 02:11 PM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
I'm running those right now and have been for the last 3 months. No probs here. They are exactly the same length as the stock NGK's just the electrode's are different.
Old Sep 4, 2001 | 03:33 PM
FlyGuy2000's Avatar
speaking of electrodes, what would cause them to deteriorate as if they're getting burnt up. my leading plug electrodes are about 1/2 the length of new ones.
Old Sep 4, 2001 | 05:19 PM
P.O.S. Racing's Avatar
Sounds like they are being burnt up, weird since the -SE recommended plugs are BR9EQ-14's for lead and trail.
On the BUR7EQ & TRAILING PLUGS NGK #BUR9EQ what's the advantage of running a hotter plug in the lead? Wouldn't the 7 tend to burn up quicker than a 9?
Old Sep 4, 2001 | 08:44 PM
rxseven's Avatar
Special Dark
The hotter plugs were used for emissions purposes I think.
Darius
85-GSL-SE
Old Sep 7, 2001 | 04:52 PM
JoseReyes's Avatar
RicanRider
I've been using the platinum tip NGK from the second Gen's for about a year now. They last about three times longer than the regular plugs. By the way I am using them on a 82 GSL 12A...and it runs much better than the original plugs....
Old Sep 7, 2001 | 04:57 PM
rreader's Avatar
Do you happen to know the number of tthe plugs you're talking about?
Thanks
Jim
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Frox
Feb 27, 2016 11:11 AM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
