turbos...need some opinions
Old May 22, 2003 | 12:07 AM
Question turbos...need some opinions
ok here goes, the second turbo isnt coming in, the first boosts up to 10lbs then drops off..havent had time to pull apart and start poking around the solenoids and vacuum lines yet which is my main guess as to what the problem is...but the question is would it be more better to make it so that both turbos spool up at the same time? i heard it makes it alot easier to work on the turbos and eliminates some problems..what about the horsepower gains/losses if any? all opinions areappreciated.
Old May 22, 2003 | 08:40 AM
Mahjik's Avatar
Mr. Links
Start here:
http://www.autosportracetech.com/RX-...leshooting.htm
If you can't fix the sequential system, then you have the option to go non-sequential later.
BLK 93
Sep 28, 2015 01:45 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
jeremyferguson4444
Sep 19, 2015 01:27 PM
mulcryant
Sep 9, 2015 05:24 PM
