Bose Radio Code? HELP
Old May 21, 2003 | 10:42 PM
Little 7's Avatar
I wanna to replace the battery but I forget the radio code. Does anyone know how to find out the code beside pay to the dealer? I heard we may call the code out from pressing some button. So, please help !!!
Old May 22, 2003 | 12:57 AM
spurvo's Avatar
don't race, don't need to
Not to offend, but if you search, you WILL find the code that the dealer uses to reset the system. It IS on this forum!!
Old May 22, 2003 | 07:29 PM
tmiked's Avatar
Waiting for the RX-9
Originally posted by newbernd
It's not that bleak.. I searched for a while to find the code.. I had one dealer tell me he had to replace the whole unit for $380. When I told him that I knew he just had to punch in a code, he hung up on me. Rediculous. Anyway:
Press "SCAN"
Press "AM/FM"
Press "AUTO M"
Press "Tune UP"
The display should read "------"
Using the memory presets buttons, enter the code "1 4 1 4"
Press "Scan" and "Auto M" simultaneously and hold until the clock appears.
The radio should now be cleared. There is a time limit on entering each command, so it may take one or two tries.
--Dave
Old May 22, 2003 | 07:30 PM
tmiked's Avatar
The info is ALMOST impossible to find in a search
Does anyone know if this works ?
Old May 23, 2003 | 02:41 AM
Kas_Rx's Avatar
Wierd, the aussie rx7's dont have a code. I've had my battery out many times.
Old May 23, 2003 | 05:53 AM
jeff48's Avatar
Rotorally Challenged
Old May 26, 2003 | 08:30 PM
tmiked's Avatar
Old May 26, 2003 | 08:39 PM
Mahjik's Avatar
Mr. Links
The code has to be set for that to be a problem. I don't believe the codes were set from the factory. I think it's a user activated security feature or mine was cleared before I purchased it, as it has never had one set during the 6 years I've owned it and I never thought it was worth it to set one.
Someone, please steal my BOSE unit to give me a good reason to upgrade it.
Old May 27, 2003 | 11:09 PM
tmiked's Avatar
¢Õ
Old Jun 10, 2003 | 05:24 AM
Phoebus's Avatar
Unhappy Radio Code
Originally posted by tmiked
hi, i tried it, but it doesn´t work!
maybe i have NO bose sound, there is another code than 1414??
i have an european 92 model, no bose, only panasonic radio...maybe youcould help me, to get the err away...
sorry about my english... :-))
greetings from sunny austria
charly
Old Jun 10, 2003 | 02:56 PM
NewbernD's Avatar
Tequila? ..it's like beer
Re: Radio Code
charly
Panasonic radio? Was that the factory radio in the UK? Here in the states, it was either Bose in the touring or an OEM radio made by (I think?) Clarion in the base & R1 models. THis code works fine with my R1 stereo.. I'd guess your panasonic is aftermarket, and has a seperate code.
Old Jun 11, 2003 | 04:49 AM
Phoebus's Avatar
Re: Re: Radio Code
hi,
panasonic is the original in europe. the buttons are the same, like the description....but after i put the code 1414 and pressing the two buttons, the "err" still comes...
i don´t know what i should do.....
greetings
charly
Old Jun 11, 2003 | 06:47 AM
NewbernD's Avatar
Sorry.. I guess I can't help then. Keep looking on the net.. I know I've seen Miata & other codes posted somewhere else a year or two earlier. You might stumble on to it.
The only other thing I could see working is going to the dealer. And that can only be ugly. Sounds like a good opportunity to put a better radio in.
..Dave
Old Apr 4, 2006 | 06:59 AM
Section8's Avatar
Does anyone else have any insight into how to make this work? I just put my car back together after sitting over the winter and the CD player doesn't work, it just spits the CDs right back out.
I tried the above sequence for about 15 minutes last night and couldn't get it to do anything.
Old Apr 6, 2006 | 02:30 PM
Section8's Avatar
bump?
Old Apr 17, 2006 | 10:38 AM
Mazda_Power's Avatar
I just want to drive it.
Hmmmm...
Anyone?
Old Apr 23, 2006 | 09:30 PM
willub and company's Avatar
Pobody's Nerfect
i have the same problem as section 8. bump?
Old Apr 23, 2006 | 11:19 PM
ZumSpeedRX-7's Avatar
rotary amuse
I called gallo mazda and they gave me a step by step procedure to fix it. id check them out. Christian. Silence in a 7 is not a bad thing, though.
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
