P/S pump
Old May 21, 2003 | 03:42 PM
DrunkenBowler's Avatar
P/S pump
When looking at the rx-7 from the front. On the p/s pulley, which way do you turn the bolt to get the pulley off? Clockwise or CCW?
For some reason, the bolt is being retarded and won't come off.
Or, I heard of a way to take off the p/s pump without taking off the pulley. Is that possible, and if so, how can I do it. Also, the a/c, can that be taken off without removing the pulley?
Old May 21, 2003 | 03:46 PM
93BlackFD's Avatar
built my own engine
counter clockwise
the pulley is plastic, so don't break it...
or do like i did, break it and figure it out later
Old May 21, 2003 | 03:56 PM
edscholl's Avatar
Re: P/S pump
ccw. doesn't take too much oomph either. i used a pulley holder, and a 10" long, 3/8" ratchet. no problem at all. you don't need to remove the pulley off the a/c, although some of the bolts are a pain in the *** to reach.
Old May 21, 2003 | 04:02 PM
spurvo's Avatar
don't race, don't need to
Power steering pump cannot be removed without pulling the pulley. AC can be pulled with it's pulley, bolts are on the side of the pump. There are 4 of em. Power steering pulley isn't that expensive if you get it from Malloy (like 65 bucks or so). That bolt is a BITCH! I broke mine getting it off... I put a screw driver into the hole, pulled like hell, broke that piece from the hole, put the screwdriver in the other hole, and got the bolt loose.
But then, I don't LIKE to follow directions like the manual told me to do!!!
Old May 21, 2003 | 04:30 PM
ArcWelder's Avatar
There is an SST for the PS pulley. It fits in the two holes and is slightly offset so a socket can get on the PS pulley nut. You can see an illustration of it in use on page C-16 of the manual('93). You might also consider using an air impact wrench.
Mark
Old May 22, 2003 | 11:58 AM
edscholl's Avatar
Mark
just go to the auto parts store and get a universal pully holder.
http://www.mytoolstore.com/kd/kdengi06.html
Old May 22, 2003 | 12:03 PM
Scrub's Avatar
bow leggin'
Mine was really hard to get off...we had a belt rachet type thing to keep it from slipping, then stokedxiv stood on the rachet....That did the trick.
Old May 22, 2003 | 07:28 PM
edscholl's Avatar
the goog thing about the universal pully holders is they generally have a really long handle. so you push on that, and can use a short handle ratchet to brace against. or just get a breaker bar for the ratchet too, then it'll be really easy.
Old May 29, 2003 | 01:56 PM
RXciting's Avatar
GrapefruitRacing?
or you can just removed the whole bracket the holds the P/S pump and AC to the engine like i did.. was a total of 3 bolts
Old May 29, 2003 | 05:14 PM
spurvo's Avatar
A bit more involved on the '93 engine I pulled than three bolts. There's the nut, and they're all pretty burried by the pumps...
Old Nov 17, 2003 | 03:54 AM
clayne's Avatar
PV = nRT
A trick myself and SanJoRx-7 learned today. Use the old belt on the pulley. Wrap it around the pulley and let it "chuck" itself tight, then put the end of the loop around the top p/s line into the pump.
When the pulley turns, it will drop all slack, tighten up, and have a friction lock - the bolt comes off.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
FC_DREAMS
Sep 9, 2015 06:24 PM
BLK 93
11
Sep 9, 2015 10:56 AM
