Idle/Throttle on 83 GS
Old May 21, 2003 | 01:16 PM
DeAdMaN's Avatar
Question Idle/Throttle on 83 GS
I have a prob. with my idle not going below 1100 ever and when i try to take off it sputters and act like its going to die. If I just give it gas it will die like it was flooded. I have to feather the gas to get the idle to go up enough to take off, and it runs ruff until it catches up with whats happening. Once I get it to idle up higher it seems to smooth out but just touching the gas from take off you think it will die unless to ease into it very slowly. I also can smell the cat going bad do anyone think that might be the prob?
Old May 21, 2003 | 01:26 PM
bliffle's Avatar
Are you putting MMO in your gas? Since I started adding 8oz MMO to each tankful both motors are running smoother. The 83 idle is so smooth you can't tell it's running!
I suspect you either have vacuum leaks or a congested carb. I assume your plugs, plug wires and dist cap are good.
B
Old May 21, 2003 | 03:06 PM
rx7gslse's Avatar
EX Pres of DFW Drunks
you can smell the cat going bad? meaning you can smell gas? does it spew black or white smoke? backfire?
sounds like a hyperactive carb to me... may need rebuilt, or it might just need adjusted. How's it run up higher in the RPM range? My friend's GS runs liek that, but mostly just because he's got a 650double pumper on it..
Come out and meet us some Wedesday night It's fun! Welcome to the board....
Old May 21, 2003 | 04:32 PM
DeAdMaN's Avatar
The cat smells like rotten eggs I don't smell gas from the exhaust. I've smelled worse it's a light smell. I tried to adjust the air bleeds but it just gets worse. I'll try the MMO Is that like two cycle oil or what? Who knows a good person to do a rebuild on the carb? Lastley that meeting it tonight Ill B there just tell me where?!.
Thanks for the help by the way
Old May 21, 2003 | 04:54 PM
rx7gslse's Avatar
https://www.rx7club.com/forum/showth...hreadid=187983
that's tonight's meet... 9-9:30 at 635 & MacArthr in Irving. We're on the southeast corner of the interchange inthe lot behind Cheddars by Starbucks. I'll be the guy in the black protege5 tonight. If you're coming or get lost, just gimme a ring on teh cell. 817-680-9968..
Unfortunately, I'm not much of a carb guru... I just know when it isn't right...
Old May 21, 2003 | 07:10 PM
DeAdMaN's Avatar
Is that the normal meeting place? Is there more info on the site about the meets? I'll see ya there B Coo
Old May 21, 2003 | 07:41 PM
rx7gslse's Avatar
yeah, that's where we've been meeting for about a year now pretty much every Wed it's not raining too hard.
We usually BS for awhile, then go for a cruise or something and end up at a place to get food/beer... It's great fun
Sulzener Racing
22
Apr 10, 2014 05:03 PM
Bass
Jul 12, 2002 06:52 AM
Dus10
Dec 31, 2001 12:45 PM
