Help Me Start My Fd.., PLLEEEAAZZZEE
Old May 21, 2003 | 04:49 AM
JSpecRZ's Avatar
NA2 Pilot
Well it's finally time to turn the key... but I wanted to get some preliminaries before I turn the key...
Basically, what do I need to do/know before starting it...
Here is the config...
New rebuild and street ported by KD Rotary (new)
Filters
Catback
Downpipe
full non sequential
removed unwanted plugs from harness (new)
stock fuel system
Power FC w/ commander (new)
Greddy pullies
NGK 9s all around
Taylor Plug wires
Do I need to add ATF before I start it?
Do I need to pull the fuel pump relay to prime the fluids? I added 5 quarts of oil (dual oil coolors) but I think it needs 6
How long do i need to crank it to prime everything?
anything else I'm missing??
I'm also worried since Jay (turbovr6) is having problems and we kinda of have the same situation besides turbo setups, so I want to do this right...
any suggestions.. .PLLLEAASE help.. today will be the day...
Old May 21, 2003 | 05:58 AM
skunks's Avatar
I'm a CF and poop smith
atf should not be needed but you can do it if you want. as for the priming the fuel system, jsut ground the f/p in the diagnostic cover for a couple of secs and then jsut start her up. good luck
Old May 21, 2003 | 08:55 AM
JSpecRZ's Avatar
NA2 Pilot
Thanks!! Since I'm running the power fc for the first time... any precautions that i need to take?
Old May 21, 2003 | 10:09 AM
ejmack1's Avatar
Lawn Ornament
i tried crankin mine over last night for the first time.... and well she wont hold an idle
Old May 21, 2003 | 10:30 AM
silver93's Avatar
all you really need to do is make sure the oil is topped off, the coolant is topped off, and yeah, prime the fuel.
if you're starting it for the first time, you should let it run for 15 minutes before shutting it off. it should make a lot of smoke (burning off hylomar and such).
as for the PFC, i started my rebuild with the stock ECU, and am waiting until i get the break in complete before i put the PFC in.
Old May 21, 2003 | 10:44 AM
bploz RX7's Avatar
I was wondering the same thing about a new Power FC... doesn't it go through a learning mode at first?? When starting a new rebuild I would think working out all the little quirks first on the stock ecu would make sense, then plug in the Power FC after you know everything is running the way it should. I will be going through this next week, hopefully .
Old May 21, 2003 | 10:55 AM
JSpecRZ's Avatar
NA2 Pilot
my problem concerning the power fc is that I am running non seq with all the emissions taken out... AWS/DT/EGR/ACV are disabled and blocked off... so if i use the stock ECU then i'll get a whole bunch of codes...
Old May 21, 2003 | 11:28 AM
bploz RX7's Avatar
son of a #$@!%... you are right about the stupid codes. I'll be running non-seq. also so I guess I'll let you experiment and see what happens so I don't make any mistakes next week
Old May 21, 2003 | 12:14 PM
twinturboteddy's Avatar
Grumpy Lurker
It's about freagin time after 2.5 years!!!!!!!!!!!!!!!!!!!
Old May 21, 2003 | 03:39 PM
JSpecRZ's Avatar
NA2 Pilot
Shuddup... LOL
Old May 21, 2003 | 03:55 PM
JSpecRZ's Avatar
NA2 Pilot
1 more hours... woo hoo
either I'll be excited.. or i'll kill myself...
Old May 21, 2003 | 08:41 PM
Tim Benton's Avatar
FD title holder since 94
The stock ecu would have had to learn the new engine as well since its been unplugged for a while. Gather sensor data at idle, idle rpms, cruising, etc. Do it with the PFC since both ecu's would have to learn the car anyways.
Tim
Old May 21, 2003 | 09:09 PM
JSpecRZ's Avatar
NA2 Pilot
WOO HOO IT's ALIVE!!!
Thanks to all that has help!!!!
rx7jocke
72
Jun 17, 2016 03:48 AM
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
