How did you get the Rear tranny and diff. oil seals in w/o the SST?
Old May 20, 2003 | 10:29 AM
wonder1and's Avatar
I Sold My Car 2 the Devil
I'm going to be doing mine (very rear seal on tranny and oil side seals on differential) but I don't have the special tool to get them in. what did you use and how did you do it?
Thanks!
Ryker
Old May 20, 2003 | 11:00 AM
paw140's Avatar
Are these seals any different than a normal shaft seal? I have always hammered them in carfully, just be careful to keep it even.
Old May 20, 2003 | 10:09 PM
cdk 4219's Avatar
A flat block of wood and a medium 5lb hammer usually help as well, keeping the seal flat while tapping it in.
Old May 21, 2003 | 09:19 AM
Zoomspeed's Avatar
if you goto autozone they rent out a seal driver set.
Old May 21, 2003 | 07:12 PM
duboisr's Avatar
Also the correct size socket with an extention for a handle will work fine .Tap it with a hammer, keep it stright .
FD7KiD
15
Feb 26, 2021 10:12 PM
sYnth.
Aug 19, 2015 06:27 PM
FD7KiD
Aug 17, 2015 11:50 PM
