Thought I blew my engine...
Old May 19, 2003 | 05:31 PM
HDP's Avatar
HDP
A Fistfull of Dollars!
Exclamation Thought I blew my engine...
I was taking my cousin for a spin in the FD yesterday on Winchester Rd. and opened it up on a long straightaway. Down shifted to 2nd and got up to about 7k, a big hesitation and BOOM... thick black smoke in the rearview mirror I was about to cry (really, I was). I pulled over at the next turn off and was shocked to hear the car running smooth. I shut it off and popped the hood and did a quick inspection and looked under the car for any coolant and/or oil. Everything looked normal and no unusual odors. So I started it again... everything checks out, nice smooth idle. So then I take off and now it accelerates harder and drives better than it did before... I'm dumbfounded
Old May 19, 2003 | 05:43 PM
rx7racer11's Avatar
thats weird sounds like you got lucky maybe you should check your air filter see if its insanely dirty or... just a thought
Old May 19, 2003 | 05:44 PM
HDP's Avatar
HDP
Brand new air filter, barely a month old.
Old May 19, 2003 | 05:48 PM
rynberg's Avatar
*What are your mods?
*Did you have an almost empty gas tank?
*Did you happen to see what boost level you hit?
Old May 19, 2003 | 06:15 PM
bploz RX7's Avatar
maybe you just unclogged your cat/hi-flow cat with your spirited drive... does the exhaust tone sound any deeper?
Old May 19, 2003 | 07:09 PM
BoOsTin FD's Avatar
Powered by** Rotary
Maybe that boom was backfire. I have dp catback and hi-flo and sometimes when i redline it and change gear, and press Accelerator i hear a boom or pop or something from exhaust. I think that's a flame to be.
Old May 20, 2003 | 12:25 PM
HDP's Avatar
HDP
I only have HKS dp and K&N drop-in filter, I think I was on 1/4 tank of gas, and the boost might have hit about 10 or 11.
The "boom" was a nasty metallic sound, that's why I thought I blew the engine.
Old May 20, 2003 | 12:59 PM
rx7racer11's Avatar
like bploz said does your car sound different you could have blown the packing out of your cat or muffler
Old May 20, 2003 | 05:32 PM
SPOautos's Avatar
Hey, where did my $$$ go?
Sounds like you need to change you plugs. How old and what plugs you running?
STEPHEN
Old May 21, 2003 | 08:43 AM
HDP's Avatar
HDP
STEPHEN
NGK. Plugs are barely a month old, maybe 700 miles on them.
renjiv2
57
Jan 25, 2024 03:34 AM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
