Idle Speed Control
Old May 10, 2003 | 02:25 PM
jdtanksley's Avatar
Question Idle Speed Control
I have been trying for weeks trying to get my car started again after doing several upgrades. Now I have several problems I am trying to resolve. The one I want to ask about here is the Idle Speed Control.
When I crank the engine a couple of times, the ISC starts buzzing loudly. Most of the time, it will continue until I kill the power. Other times, it eventually stops. Is it toasted, or is the ECU (Power FC) trying franticly to adjust the idle?
Thanks…
Old May 10, 2003 | 02:31 PM
SilverRX7's Avatar
Im not an expert on the rx-7 ecu.... but usually the idle speed controller is open loop... so it has a certain set of parameters that it runs... so I don't believe the controller would be the root cause of your problem... it sounds like a hardware issue(proly unrelated to the mods you did).
Old May 10, 2003 | 11:40 PM
Trout2's Avatar
I've encountered the buzzing noise from the Idle Speed Control Motor on a few FD's with PowerFC's including mine. ISC failure is not very common and even with Malloy Mazda's discount it is over $400 for a new one.
Jack
C. Ludwig
Jan 30, 2019 06:31 AM
imitek
Aug 28, 2015 05:28 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
