I need quick answers!!!!
Old Aug 31, 2001 | 09:44 AM
JoshP's Avatar
Thumbs down I need quick answers!!!!
alrighty then...
i took my car up to my uncle's garage last night to replace my starter that went sour the day before.
the problem with the starter that went bad was that the little gear would pop out momentarily and then pop back down without the starter trying to turn it! it would just go click, click, click. so i said, okeday, lets get a new starter. got a new starter, put it in and it the same exact thing!!! damn!!! i'm hoping that it is just the starter, because it gets the whole 12 volts that it needs continuously when i try and start it. it's not the battery, or the alternator (brand new) but i'm just worried shitless that it is more electrical problems! can someone help quick!! i need to get it running for the weekend!
Josh
thanks guys
Old Aug 31, 2001 | 09:51 AM
P.O.S. Racing's Avatar
Sounds like your solenoid isn’t getting all the juice it should. It’s what pushes out the gear to engage the flywheel. Does the start motor turn even with the solenoid pushing the gear up?
Double check the ground leads between your engine an chassis, as well as the ground to the starter itself.
Old Aug 31, 2001 | 10:18 AM
JoshP's Avatar
Thumbs up it's ok
the gear actually gets pushed out, but the motor never starts to turn it. it's getting all the power it needs (if 12 volts is correct)!
i just hope it's the starter!
Josh
thanks
MyRxBad's Avatar
EliteHardcoreCanuckSquad
First things first...
When you had the stater out of the car. Did you test it?
I usually use battery jumper cables.
Hook the ground up to the casing of the stater and put the positive on the one were the battery cable connects to it.
Now get yourself a long screwdriver and touch one end of the screwdirver to the positive jumper lead and the shank of the screwdriver to the little male electrical connector. The stater should shoot forward and spin.
If it doesn't then it's you starter. If it does, you need to change the battery cables (not too hard of a job), assuming that you have a new alternater and battery of course.
just did this procedure 2 weeks ago, when I bought a new starter, and then it didn't work.
Plus this is a good way to test your battery cables as well.
PS - Changing the battery cables is also a good reliability mod.
Old Aug 31, 2001 | 10:30 AM
JoshP's Avatar
Thumbs up yeah, i tested it
i tested it, but not that way.
we just took it off of the mount, hooked up the wires and watched it pop in and out.
i guess it could be the cables, but i'll test it that way also!
thanks
Josh
anyone else with similar experience?
thanks
Old Aug 31, 2001 | 10:32 AM
Felix Wankel's Avatar
Super Newbie
Check the ignition switch too.
Old Aug 31, 2001 | 10:33 AM
JoshP's Avatar
where?
where exactly would the ignition switch be located?
thanks
Josh
Old Aug 31, 2001 | 10:37 AM
Super Newbie
Re: where?
thanks
Josh
Its the thing that you put your key in to start the car....
Old Aug 31, 2001 | 10:39 AM
JoshP's Avatar
Thumbs up hahaha
yes i know!!!!!
but what should i check for?!
do i need to take it out?
thanks felix!!
Josh
Old Aug 31, 2001 | 10:45 AM
JoshP's Avatar
Thumbs down okay
also, about 2 months ago, i tried to start the car and it went "whhiiiiirrrr". the start started turning, but the solenoid never popped it out. that happened about 3 more times within the past 2 months up until now. just thought i'd add that into the equation.
thanks
Josh
Old Aug 31, 2001 | 10:48 AM
Re: yeah, i tested it
thanks
Josh
thanks
Did the starter spin?
Still think it's a ground problem.... Just my $1.98.
Old Aug 31, 2001 | 10:50 AM
JoshP's Avatar
Thumbs up negative
it never spun up
bummer
Old Aug 31, 2001 | 11:04 AM
Re: negative
it never spun up
bummer
I.m sorry but I’m not following you.
When the starter gets juice two things happen
1. the solinoid kicks the starter gear up.
2. the starter motor spins
Which of these is yours not doing?
Old Aug 31, 2001 | 11:08 AM
JoshP's Avatar
Thumbs up no spinnage
the solenoid pushes the gear out, but the motor never spins.
but, the solenoid just pops it out and then it falls back down.
so, what's happening is that the gear isn't staying in place long enough to kick the motor off! (i think) hehehe. so i dunno! but that's the order of events: the gear pops out (then back down) but the motor never starts up. the gear should stay up as long as i have the ignition turned to he start position.
Josh
thanks
Old Aug 31, 2001 | 11:16 AM
Re: no spinnage
Josh
thanks
Sure sounds like a bad starter, just weird that a new died. Take it back and get them to test it. I’d also have them test the replacement a couple times before you leave the store.
Good Luck,
Old Aug 31, 2001 | 11:51 AM
JoshP's Avatar
Thumbs up yeah
yeah, that's what my uncle's gonna do.
thanks guys, i think this post has blown up pretty fast!! that's the way i like it!!
Josh
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
Captain Hook
13
Oct 4, 2015 06:35 PM
Zinraf
Oct 1, 2015 01:09 PM
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
