Clutch Question
Old May 8, 2003 | 05:58 PM
meddle's Avatar
Clutch Question
My car has basic bolt-ons; Dp, mp, cb, intake, FMIC and will be running 12psi on my PFS. I am hoping for something in the neighborhood of 300whp on a brand new reman. My question is this, on this mild set-up, is it rerally worth upgrading the clutch? I am going to purchase a new clutch while my car is in pieces, but am not sure if I can stick wiht O.E.M, or if a ACT s/s is neccesary. Any input would be appreciated.
Old May 8, 2003 | 06:05 PM
i dont think you will need a new clutch for that..... unless your clutch is going out already.
Old May 8, 2003 | 06:13 PM
meddle's Avatar
Well thats not exactly the question. I am replacing the clutch regardless. The question is, wiht my mild mods, is it neccesary to drop the extra 200 or so bucks on an upgraded clutch versus an O.E.M.
Old May 8, 2003 | 07:43 PM
Mahjik's Avatar
Mr. Links
Yep, I think you will wear out the OEM on those mods fairly quick. You have a FMIC and a mp but I'm running higher boost and my stock clutch is gone. I'm in the process replacing it with an ACT S/S clutch and a RB 9.5lbs flywheel (waiting for some othe parts to arrive to finish it up).
You may as well upgrade the clutch from OEM so at least you have room to grow should you decide to later down the road. After starting this clutch job, I hope I never have to do it again (big thanks to the local guys for the help!).
Old May 8, 2003 | 07:47 PM
c00lduke's Avatar
I'm with Mahjik, there are some pretty mild ACT clutch kits and it gives you room to grow. Upgrade that little ****.
Old May 8, 2003 | 08:05 PM
meddle's Avatar
Thanks for the input. Went ahead and ordered an ACT s/s.
Old May 8, 2003 | 08:06 PM
Mahjik's Avatar
Mr. Links
Good luck! Make sure to either get your current flywheel resurfaced or purchase a new flywheel for your clutch install (if the flywheel has never been replaced).
Old May 9, 2003 | 03:06 PM
Tomco78's Avatar
I had almost the exact same setup.
My OEM clutch with brand new Racing Beat S/S disc only lasted about 3 months.
Need a new one now....
Old May 9, 2003 | 03:55 PM
adam c's Avatar
Cheap Bastard
I think you will like it. I do.
alphawolff
Nov 17, 2015 05:57 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
