Sponsored by: CARiD
13B treatments for better compression
Old May 6, 2003 | 07:36 AM
Element's Avatar
i heard that you can add something to your engine that will harden the apex seals to give you better compression it was a three letter name if i remember correctly anyone know what im talking about?
thanx
Old May 6, 2003 | 10:26 AM
hugues's Avatar
Why am I here ?
you mean ATF ...
Lots of controversy about this
Do a search about 'atf treatment' and you will find plenty to ponder about
Hugues -
Old May 6, 2003 | 12:21 PM
Cosmo Donk's Avatar
Queer
Doesn't harden anything, just loosens up the springs if they are sticking. I have seen a guys T2 go from no compression, because it was flooded, back to good compression because we put ATF in there to lube stuff up. If your car is ever spinning with no compression after you flood it, you can put some in the chambers. I am sure oil would work as well if you don't want to use ATF for some reason.
Old May 6, 2003 | 06:50 PM
Element's Avatar
what do you mean by chambers
Old May 6, 2003 | 08:39 PM
1984special's Avatar
So little time and money
I believe the chamber is the combustion chamber... in another words you take out the spark plugs and pour it in. Do a seach because I'm not too sure.
Old May 7, 2003 | 10:56 AM
Cosmo Donk's Avatar
Queer
Yah, what he said.
Leave the plugs out, squirt in about a cap full of ATF, and then crank the engine without fuel or spark. You can do this a few times to get a good coating.
Lou Byer
20
Oct 12, 2020 08:03 PM
squirrels
Sep 24, 2015 03:33 PM
ZacMan
Sep 19, 2015 09:20 PM
mulcryant
Sep 9, 2015 05:24 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
