Magnacor vendor/transmission help
Old Aug 30, 2001 | 12:31 PM
takerwolf's Avatar
Where can I get the magnacor wires? Also my car shifts kind of hard, expecially into 5th or Reverse, even pressing the lever over that way is harder. Sometimes it even clunks when shifting into reverse or *grimice* grinds the gear when shifting to 5th on rare occasions. Car only has 53,000 miles on it. Would bad bushings cause this? Also, would the mass air flow sensor off a 89-91 fit on an 86 (for easier cone filter mounting).
Old Aug 30, 2001 | 10:21 PM
Keith's Avatar
Unhappy
Sorry, the MAF for an 86-88 is different (mechanical flap) versus the 89-91 (rotating cylinder, I think). The ECU signal is different also. Magnecor wires can be purchased from Magnecor, Mazdatrix, Rotary Performance (rx7.com), and many speed shops, both on-line and local.
Irv, Keith's dad
Old Aug 30, 2001 | 11:48 PM
Dak's Avatar
Dak
Information Regurgitator
Might try putting a good synthetic oil in the gearbox.Shifter bushings aren't exspensive so I'd change them but I don't think bushings would cause it to grind.I'd try the synthetic and see what happens.Alot of people like Redline.I have Mobil 1 in mine.I've heard Royal Purple is good too.
localized
Sep 16, 2015 12:18 AM
vipernicus42
Apr 23, 2006 05:18 PM
93 R1
24
Jun 21, 2004 11:15 AM
Dak
Apr 24, 2002 01:40 AM
rx7eaven
16
Jan 3, 2002 01:11 AM
