Sponsored by: CARiD
Rust on my pressure plate....
Old May 2, 2003 | 04:11 PM
Turbo Driver
I'm in the process of swapping motors in my car, and the engine I'm using already has a low milage clutch/plate/flywheel on it. But there's rust on the pressure plate. I'm not talking holes rusting throughit, etc....but surface rust. Is this ok to use? It's temporary anyway until I buy a new clutch, but I want to get the car on the road now, is it ok to use it?
Old May 2, 2003 | 08:30 PM
duboisr's Avatar
Do not waste time typing questions just sand the rust off with rough sand papper. Do the pp and the flywheel to remove the glaze . Then it will be as good as it can be .If the fiber disc is glazed smooth, sand it to. alittle will do it .
Old May 2, 2003 | 08:51 PM
Turbo Driver
Yes, I should've known better. Next time I'll just guess and keep my fingers crossed that it works. If it was your car maybe you'd feel a little different.
Old May 5, 2003 | 06:53 PM
jgrts20's Avatar
Who are you?
dont worry man, thats why these forums r around to ask peeps questions!! PEACE!!
Old May 9, 2003 | 01:39 AM
Flyrx7's Avatar
Money Pit
Don't forget to spray it down with a good degreaser, like Brake-Clean.
Frank
13
Jan 9, 2018 11:19 AM
sinclair7seven
11
Sep 11, 2015 10:15 AM
t-von
Sep 10, 2015 01:56 PM
vmerino
Sep 5, 2015 11:26 AM
