Squeeking hood!!!
Old Apr 30, 2003 | 08:00 PM
half past twelve's Avatar
Squeeking hood!!!
Holy ****, I cant take it anymore. It squeeks over any bump. I went out and bought some lithium grease (got white on accident) and put that on each rubber stub, the latch, and where it connects to the car. Fixed that job, I was so damn happy. But after 5 minutes of driving it came back. WTF do I do to make it stop!
Old Apr 30, 2003 | 08:18 PM
phlanigan's Avatar
Put some rubber washers under the 4 rubber stops around the hood (cut the washers and slide them in place) and put some tape around the U bolt on the hood. Worked for me...
Old Apr 30, 2003 | 08:28 PM
ricola555's Avatar
I feel your pain. A squeaky hood can drive you nuts. I was just discussing this very issue with my wife. She mentioned that my car didn't "squeak"anymore. I thanked her for this astute observation, and reminded her that she's ruined my life.
As for the squeak...Here's what worked for me. I lubed and tightened the four nuts holding the hood on(two on each side). Then I lithiumed greased the latch like there was no tomorrow. Then I glued the rubber stops to the car so they wouldn't keep rotating. It's worked like a charm so far.
Old Apr 30, 2003 | 08:42 PM
same thing happens to me.....=/
Old Apr 30, 2003 | 09:18 PM
rynberg's Avatar
I didn't use lithium grease, I use Mobil synthetic grease -- it's purple and comes in a tube (like for a grease gun). I have to reapply it to the four rubber stops and the latch every 3 months or so.
Old Apr 30, 2003 | 10:08 PM
ArchangelX's Avatar
Hell..I just wrapped the stumps with black electrical tape and called it a day. Worked like a charm..lol...
Old Apr 30, 2003 | 10:52 PM
Montblu's Avatar
Unconfirmed
Try the small rubber rounds for furniture legs. They already have sicky on one side. put them on the Hood side where they meet the rubber stoppers. Takes a day or so for the rubber to make a good dent in the rounds, but it stops the squeeeeeeeks immediatly.
Old Apr 30, 2003 | 11:25 PM
SpiritR's Avatar
adjust the latch?
Also maybe some electrical tape on the latch hook
Old May 1, 2003 | 07:04 AM
moehler's Avatar
Lubed the hood hinges w/ wd40 and used electirical tape on the U-bolt. This has held up for four months so far...
Old May 2, 2003 | 07:37 PM
fixed it!
I went to the local auto store and went to the HELP! section. Got a power brake check vavle gommet. Took it cut it in half and the cut another part so I could open it. Jammed them underneath the two driver side rubber things, and VOILA no more squeeks. Work like a charm...
Old May 3, 2003 | 02:54 AM
JammerRX's Avatar
Originally posted by SpiritR
adjust the latch?
This is the way to fix it...just wrap electrical tape around the hook that latches in the front...
Old May 3, 2003 | 09:42 AM
RonKMiller's Avatar
Blow up or win
Old May 3, 2003 | 10:14 AM
Sqeaking hood
Mazda has changed the hood stops in the front adding a half of inch to the material. Totally resolves the problem
Old May 3, 2003 | 10:32 AM
Street King's Avatar
*** Bless Texas!
Don't use WD-40. It's not a form of grease, it's really a solvent. The tape seems to be the thing that's working.
ls1swap
Jun 3, 2024 03:25 PM
