Turbo II Tranny Question
Old Apr 29, 2003 | 08:19 PM
Jesuscookies's Avatar
I can haz rotary?
Is there a way to tell the difference between a Series 4 87-88 TII transmission, and the later, Series 5 89-91 TII tranny just by looking at it?
Thanks
Old Apr 29, 2003 | 09:14 PM
I can haz rotary?
A little love please
Old Apr 29, 2003 | 11:01 PM
RX-Heven's Avatar
I'll blow it up real good
The series 4 tranny mounting bracket (cross brace) has only two bolts that attach to it from the bottom, one on each side not counting the side rubber mounts. The series 5 mounts with two bolts on each side (4 total), also not counting the side rubber mounts. They have different ribbing on the case, and both fill hole locations are different. The latter differences are hard to distinguish from one another without having them side by side.
Old Apr 30, 2003 | 12:01 AM
Spraintz's Avatar
Edmond Dantes
definately the ribbing and if i am not mistaken the location and size of the soloenoid thing for 5th gear switch and reverse switch is pretty different.
Old Apr 30, 2003 | 12:08 AM
GtoRx7's Avatar
Collections Hold
Im also having the same problem, I got a tranny from japan, and cant tell if its a 88 or a 89. Arent the shifters different from 87-88 and 89-91? Because I have four bolts holding on the rear bracket, but my 84' shifter fits into the transmission, so I thought it was a 88'. Let me know too, thanks
Old Apr 30, 2003 | 01:44 PM
RX-Heven's Avatar
If yuou have four bolts holding on the rear bracket, you have an 89-91 tranny. Shifters are the same
Old May 1, 2003 | 06:24 PM
GtoRx7's Avatar
Collections Hold
Why does mazda trix have different numbers for the short throw in a 84-88 , and 89-91? is it just a length difference?
Old May 1, 2003 | 06:36 PM
Lodivigo's Avatar
Is it running yet?
Thread Pitch for the shift ***** are different between an S4 and an S5, I have no clue on the FB though.
smikels
Rtek Forum
May 12, 2016 12:34 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
