I am making too many hydrocarbons. would you like some?
Old Apr 23, 2003 | 02:17 PM
thorin's Avatar
hydrocarbons. over 1000ppm of them at idle. I need to get it down to 460 to pass aircare.
all the rats nest hoses seem to be hooked up, the car runs just fine. tried advancing the timing, and they went waay down. but is it not dangerous to run full advance? should i put in some higher octane fuel if i do? retarding the timing made it much worse. isnt it supposed to be the other way around?
Old Apr 23, 2003 | 02:55 PM
Well, my dad used to put high grade alcohol in his tank before he went for his emmissions testing.... you could give that a shot.
Old Apr 23, 2003 | 03:14 PM
BRealistic's Avatar
Maybe the cat is bad??? They do get used up y'know. Maybe time for a Bonez?
Old Apr 23, 2003 | 03:25 PM
TheTwinTurboRX-7's Avatar
send me all you like, I have no emissions testing
Old Apr 23, 2003 | 04:29 PM
j9fd3s's Avatar
Community Builder
well if you can run tons of timing and pass, then reset it to normal then thats ok.
check your acv, there is a hose that goes to a grey thing on the air cleaner, make sure there is no air coming out of this hose below about 2500rpms
mike
Old Apr 23, 2003 | 05:32 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
ACV
Air Cleaner
Cap and Rotor
Plugs
Clean out carb
Tune up
Cat
All else fails pour some denatured alcohol in the fuel tank. You can buy it at KMart. Run the car hard, heat up the cat good and pull into smog shop.
Less than 28* total timing @ 4000rpms is fine. Most Pro7 racecars use 24-28*. Although I'm hesitant go over 24* personally, especially in heat.
Old Apr 23, 2003 | 09:00 PM
thorin's Avatar
ahh... if only. actually, im trying to pass emmissions so i can sell the car. cant afford to move out, go to school and drive my 7. so in fact would be more apt.
thanks for the suggestions guys. I have to fix this by may 9th when my insurance rusn out or i will be up a certain creek(you know the one) without a paddle.
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
jsesq
27
Sep 25, 2015 11:10 AM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
