checking solenoids
Old Apr 16, 2003 | 10:17 AM
Zoomspeed's Avatar
checking solenoids
how woudl I go about checking the vacuum solenoids to amke sure they are working right?
Old Apr 16, 2003 | 10:31 AM
93BlackFD's Avatar
built my own engine
bake them in an oven, check the resistance across the two poles
they should all say the same
Old Apr 16, 2003 | 11:07 AM
dubulup's Avatar
development
That's weird.
Not to techincal, eh?
I'm sure if you search you'll find a better explaination...I've never checked one, sure did get rid of a lot of them, though
Old Apr 16, 2003 | 11:21 AM
Cihuuy's Avatar
dats a good question... i was going to do that when i did the simplification... but i didnt coz i didnt have the time... i know i was blowing into them to check for the flow but the technicall side is??? let me check in the manual...
Old Apr 16, 2003 | 11:23 AM
Cihuuy's Avatar
by the way... hows ur progress??
Old Apr 16, 2003 | 11:45 AM
JONSKI's Avatar
5yr member, joined 2001
Procedure for checking solenoids starts on page F-190 of the FSM.
Old Apr 16, 2003 | 11:56 AM
Cihuuy's Avatar
hmmm... you beat me to it Jonksi.. hihi
you will need a circuit tester to do this... and do a flow test on all 3 nipples..
Old Apr 16, 2003 | 02:17 PM
wonder1and's Avatar
I Sold My Car 2 the Devil
or you can do it my way...
hook a small piece of vac. tube to each nipple and blow through the nipple that is on the same side as the electric hookups and see where it comes out... then get a battery charger and put a 12v current through it while blowing through the same tube.... see if the air has been rerouted and also if there is any leaking through... kinda ghetto but it works!
-R
Old Apr 16, 2003 | 04:23 PM
Zoomspeed's Avatar
Thanks for the help guys
lol haven't even started yet, need to order my hoses and block off plates still.
Old May 23, 2003 | 12:25 AM
Zoomspeed's Avatar
Do I need ot heat up the solenoids in order to get an accurate test?
24seven_dada
20
Nov 10, 2018 12:03 PM
firzen
Sep 15, 2015 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
rotor_veux
Sep 3, 2015 07:10 PM
