what size injectors should i get?
Old Apr 16, 2003 | 12:58 AM
i want to upgrade my boost and i need a power fc, fuel pump and bigger injectors. what size injectors do i need? i was thinking the 1300cc ones. can i controll that with a power fc or do i need an apexi ems? im pretty new with my fd and it runs great. i already know bout getting cat bak, dp and intake and ish like dat. i want to get my car to 12-14lbs of boost. what do i need that i forgot bout? dont blast me either!
Old Apr 16, 2003 | 01:04 AM
Dougie_fresh_007's Avatar
well the power fc is a stand alone... and the 1300 cc secondaries should be sufficiant for those boost levels
Old Apr 16, 2003 | 01:27 AM
skunks's Avatar
I'm a CF and poop smith
make sure you flow test the 1600cc ones if you do go with them! They seem to all be a bit off, sometimes by a lot...
Old Apr 16, 2003 | 04:16 AM
rynberg's Avatar
If you want to run 12 psi daily:
*cat-back
*downpipe
*intake
*upgraded intercooler
*ecu or Power FC
If you want to run 14 psi daily:
*add 1300cc or 1600cc injectors
*add higher flowing fuel pump
The PowerFC can handle larger injectors.
Old Apr 16, 2003 | 10:06 AM
apneablue's Avatar
This is kinda fun to play with...A fuel calculator from Rotary Performance in Garland
Fuel Calculator
Old Apr 16, 2003 | 06:10 PM
if i get the 1300cc secondary injectors what about primary?
Old Apr 16, 2003 | 06:32 PM
artguy's Avatar
WTB** Very Low Miles 94-95
rp's calculator is way off....at least for me....im pushing 381 at 80 percent...almost a hundred less than they say via that calculator
stock primarys are fine if you are running 14lbs on stock turbos
j
Old Apr 16, 2003 | 07:16 PM
maxcooper's Avatar
WWFSMD
Jason, 550/1300 at 80% yields 446 flywheel HP, which is about right for 380 RWHP.
Partially inspired by RP's page, I wrote a much more comprehensive one that some of you guys might find useful. This **** isn't rocket science, but it does take some knowledge to understand how it all works together. I have some links and explanatory text on my page that is intended to help you gather that knowledge:
http://www.maxcooper.com/rx7/how-to/...tem/calcs.html
-Max
Old Apr 16, 2003 | 07:37 PM
grinn253's Avatar
*cat-back
*downpipe
*intake
*ecu or Power FC
Can someone concur?
My goal is running 12psi daily with those above mods...and also a mild street port/ported wastegate.
thanks!
Edgardo
ps. Plausible to add high flow cat into the mix as well without upgrading the fuel system?
Old Apr 25, 2003 | 03:49 PM
grinn253's Avatar
Okay i went to maxcooper's link, and i have a question:
Under "max duty cycle" it says the stock 93-95 RX-7 ECu tops out around 63%
I then entered 550 primaries and 1300 for secondary, keeping the max duty cycly option at the stock ecu's max at 63%.
with that setup its says i should be able to support 343Flywheel HP or 292RWHP
Here is the question:
Does that mean with stock ECU and larger 2ndary injectors, I should be good up to 292RWHP? (BTW i have the supra pump as well)
thanks!
Old Apr 25, 2003 | 04:28 PM
Snook's Avatar
Tony Stewart Killer.
you cant run different sized injectors with the stock ecu it doesnt know how to control them
Old Apr 25, 2003 | 04:37 PM
turbogarrett's Avatar
0 lbs of boost
get a pfc or the ems if you're planning on larger injectors.with a standalone you can run as much duty cycle as you want( up to 100%). i hear 80% is a good maximum number.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
