what is this wierd ringing sound i get at about 5000rpm?
Old Apr 15, 2003 | 01:14 AM
thorin's Avatar
85 gsl, 12a.
when i rev past 5000 rpm, i get this weird metallic rining noise that seems to be coming from the engine bay. it gets exponentially louder untill it becomes quite frigtening at about redline.
what could this be? i still have the stock clutch fan... could that be it?
Old Apr 15, 2003 | 10:41 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
Do you still have an air control valve?
Old Apr 15, 2003 | 11:10 AM
O 16581 72452 5's Avatar
The infamous number guy!
As weird as this sounds... replace your belts, i had the same ringing that went away as soon as i replaced my belt.
Old Apr 15, 2003 | 11:13 AM
Cody's Avatar
SKELETOR!
The stock clutch fan isn't quite a ringing. Its more like a whoosh of air. Of course, the fan CLUTCH is there to prevent it from spinning above a certain RPM, since that will stop being effective, and start slowing your engine down. My clutch fan noise is a combination of the tornado whirring, and the belt starting to squeal.
Old Apr 15, 2003 | 11:21 AM
That's not your clutch fan, i had an e-fan and still had that whooshing noise and metalic ring as he described it.... both of you replace your belts.
Old Apr 15, 2003 | 10:05 PM
subgraphic's Avatar
I had the -exact- same thing happen to me. Sounds like glass bell ringing. Its was the belts.
scot
Old Apr 16, 2003 | 08:19 AM
timmya2's Avatar
i have a sound.. when im doing 100 at first gear..
but i dunno if i can call it "ringing" exactly....
but it is something differnt..
people just said it was the rotary engine
Old Apr 16, 2003 | 01:07 PM
Kind of sounds like a tapping? it's hard to describe... every strange noise i've heard from under my hood has been belt related... ac compressor was out, made strange noises, took it out, cleared that problem, then another came up, replaced the belt and everything is fine, no strange noises under the hood.
MILOS7
Oct 1, 2015 08:00 PM
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
