remove oil metering pump ??
Old Apr 14, 2003 | 11:31 PM
hamster's Avatar
Hey all,
have any of you removed the oil metering pump? How did you block of the hole(s)? Is it hard to do?
Mark
Old Apr 15, 2003 | 12:33 AM
REVHED's Avatar
Hunting Skylines
Easy. All you need to do is make a block off plate. Use aluminium as it's easy to work with.
Old Apr 15, 2003 | 11:05 PM
ZigZag's Avatar
Remove metering pump?
Pardon, but why on earth would you want to do that?
Old Apr 15, 2003 | 11:08 PM
Keaponlaffen's Avatar
remove it, run pre mix....
OMP = mechanical, mechanical parts fail.... last thing you want is no oil getting to your apex seals.... Also, it injects your dirty old engine oil with carbon deposits, etc in it into your engine... not necessarily a good thing...
Premix = easy, and reliable (unless you have a REALLY bad memory)
AND to top it all off, you get REALLY great looks when you're standing at the gas pump dumping in a bottle of 2-stroke mixing oil
Old Apr 15, 2003 | 11:12 PM
AdrenalifeRX7's Avatar
Are you gonna shift?!
Re: Remove metering pump?
One reason is if for wanting to run full premix instead of using an OMP. Personally I would do the premix over using the OMP since it enables me to use Marvel Mystery Oil and/or 2 cycle oil in with my gas. Better atomization and you have the insurance of knowing that the apex seals are getting the lubrication they need. Very rarely do the mechanical OMP's fail, but they do fail. I have a leaky one on my motor as we speak. It's not putting out enough oil into the intake manifold, so I decided to use MMO as my premix and my car has NEVER ran better than it does now.
NATE
Old Apr 15, 2003 | 11:20 PM
Beatcha
Old Apr 16, 2003 | 05:48 AM
SoRRoW's Avatar
MY NEW NAME IS ROTARY 7S
Any of you guys know if we can or know where to buy block off kit?
If not..maybe ill buy a sheet of aluminum and make mine and a few..
Old Apr 16, 2003 | 08:15 AM
AdamAnt's Avatar
Where do you get MMO, and how much do you mix in a full tank. Does it stay mixed with the gas well?
Old Apr 16, 2003 | 01:13 PM
You can't get MMO in Canada, so you'll have to settle for 2 stroke oil. I think the ratio for a full tank was a 16 oz bottle per top off. It mixes really well and gets burnt off good too. It is probably one of the best internal cleansers.
Old Apr 16, 2003 | 11:17 PM
ZigZag's Avatar
Ah. I see. Thanks for the info.
Old Apr 17, 2003 | 01:56 AM
dump in a bottle, jump on the rear bumper a few times to mix it up, get in, start up, drive away
nah, all you have to do is take a few corners and it'll be all mixed up...
Old Apr 17, 2003 | 05:13 AM
Ultralights's Avatar
I usually add the oil BEFORE i fill the tank.
but i usually run the tank down to the last few Litres most times, so when the oil is added firsts, then the tank filled, it gets well mixed.
Th0m4s
Feb 26, 2019 02:04 AM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
