What do you suggest?
Old Apr 14, 2003 | 11:03 PM
RX7SpiritR's Avatar
The Spirit of FLUFF!
I'm going to be pulling out about a $5,000 loan to pay for the rebuild and other things. OK, so far I'm going to spend about $3,000 on streetport, and 3mm apex seals, then gonna spend about $1200 on PFC which comes to $4200. I have about $600 left over giving myself a $200 cushion. What should I get? And BTW I will be doing the non-seq mod while the rebuild is going in. I saw on rx7store.net that there is a special for brembo rotors all around hawk hp pads for front and steel braided brake lines all around too and I was thinking of getting that, the other thing I was thinking of was getting new shocks and springs. But what do you guys suggest?
Old Apr 15, 2003 | 12:14 AM
2GSLSE's Avatar
#1replace ALL of the coolant hoses/ fuel lines, pulsation damper check motor mounts
#2get more money
#3clutch/flywheel
#4get the pfc tuned
Old Apr 15, 2003 | 06:52 AM
dubulup's Avatar
development
coolant lines...that's your $200 cushion...
Hoses Part Number
HOSE UPPER RAD 93-95 15-186B-N3A1 $23.13
HOSE LOWER RAD 93-95 15-185B-N3A1 $15.04
HOSE HEATER 93-95 CORE TO PIPE R 61-211A-FD01 $8.02
HOSE HEATER 93-95 PIPE TO CORE L 61-212A-FD01 $8.51
HOSE HEATER 93-95 PIPE TO RAD(R) 61-214B-FD01 $10.16
HOSE HEATER 93-95 ENG TO PIPE(L) 61-213B-FD01 $14.46
HOSE WATER DISCONECT 93-95 61-240A-B455 $13.22
HOSE WATER 93-95 TT FILLER NECK TO TANK 15-183A-N3A1 $9.42
HOSE WATER 93-95 TT LOWER RAD TO TANK 15-184A-N3A1 $16.43
HOSE WATER 93-95 TT PIPE TO THROTLEBODY 13-691A-N3A1 $25.25
HOSE WATER 93-95 TT TANK TO OVERFLOW 15-380C-N3A1 $4.68
HOSE WATER 93-95 TT R.HSG / THROTTLEBODY 13-681A-N3A1 $19.17
HOSE WATER 93-95 TT TURBO TO RADIATOR 13-5360-N3A1 $8.99
HOSE WATER 93-95 TT WATER PUMP TO TURBO 13-54X0-N3A1 $5.51
Total
$181.99
Old Apr 15, 2003 | 07:27 AM
paw140's Avatar
Why are you going with 3mm seals, and why are you going non sequential? Are you doing the work yourself? Because you have not budgeted anything for labor... You also need to consider the cosdt of the turbo mods for non-seq.
Does your sequential system work correctly?
Old Apr 15, 2003 | 08:58 AM
apneablue's Avatar
R U pulling the motor yourself? I was quoted 5.5k for a streetport from RP for pull / rebuild / install / pickup
Old Apr 15, 2003 | 10:34 AM
Engberg's Avatar
I'm surprised no one asked what he has already done to the car. Are you caught up on routine maintance? (Fuel filter, brakes, is your suspension getting soft) A mod list would help.
Old Apr 15, 2003 | 11:05 AM
paw140's Avatar
Wait a sec... aren't you the guy that bought the car with a new motor, from a dealership? Why are you putting another motor in?
Old Apr 15, 2003 | 11:08 AM
dubulup's Avatar
development
Aren't you the guy who was a dick to everyone on the board and then played us by saying that it was you younger brother???
Old Apr 15, 2003 | 11:11 AM
apneablue's Avatar
Old Apr 16, 2003 | 08:33 PM
RX7SpiritR's Avatar
if your still gonna go on about that then wwhatever it's been over for a while now. Anyways, all maintenance has been done up to date and the engine went since I blew an apex seal. The prices all include labor and the pfc comes to me tuned, then I'm taking it to one of my buddies that will dyno tune it for $50. I'm getting 3mm apex seals because they are beefier and will hold better, I am thinking of getting 2mm since I do more autoX anyways and I'll be staying in higher RPM's more often. Thanks for the advice and thatnks for being mature about it......
Old Apr 16, 2003 | 08:41 PM
RonKMiller's Avatar
Blow up or win
DAMN, now he's so upset he's stuttering!
WWHATEVER.
Everyone on this forum has loonnnnnngggg memories.
Old Apr 16, 2003 | 08:59 PM
turbojeff's Avatar
Do it right, do it once
PFC, waste of $$ unless you have supporting mods.
3mm seals, don't need them either.
Re-do your plan.
$2000 Mazda reman
$450 ACT street strip clutch
$450 Fluidyne radiator
$79 fuel line recall kit
$180, all coolant hoses mentioned already
$30 new belts
$125, clean and flow test injectors
$100 Fuel pulsation damper
$40 4mm silicone hose
$55 new plugs and wires
$30-40 for engine oil, gear oil and antifreeze
$250 for ONE motor mount, you might need both or none
$100 engine gasket kit
$100 turbo gaskets
$ 40 fuel filter
I'm sure I'm forgetting something but this is a good place to start.
You can get a discount on parts if you ask, 20% is usually not to tough to get. Malloy Mazda (Ray Crowe) and Mazdaformance and a couple of good choices to go with.
I think you had a DP, if not budget in a few bucks for that too.
Your simple $3K motor and $1200 PFC is far from getting you a nice running driving RELIABLE FD. Doing it your way will produce another low mileage blown motor. No flames, just the facts.
Old Apr 16, 2003 | 09:01 PM
turbojeff's Avatar
Oh yeah, and I remember you to.
I'm forgetting about it. I'd just like to see how you respond to my post. I've put about 20 engines in FDs, I know what I'm talking about.
Old Apr 16, 2003 | 09:41 PM
xstacy7's Avatar
I love when things work
WWHATEVER.
dang....I miss everything
Old Apr 16, 2003 | 09:45 PM
xstacy7's Avatar
hey turbojeff, where can you get a fuel filter for $40, I paid around $50 for mine, I'd like to save a little if I have to get one again
xstacy7's Avatar
sorry double post
Old Apr 16, 2003 | 09:53 PM
wishbanzai's Avatar
The Koyo's are going for $350 SHIPPED now on e-bay!!
Old Apr 16, 2003 | 10:21 PM
turbojeff's Avatar
My prices were estimates. I get my fuel filters for about $35 from Mazdaspeed (AKA Mazdacomp).
93FD510
Oct 1, 2015 02:00 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
lnlreaper
Sep 27, 2015 09:59 AM
Broke_A_Baller
Race Car Tech
Sep 24, 2015 09:27 PM
