O2 sensor!!
Old Aug 25, 2001 | 04:26 PM
Turbocharged's Avatar
O2 sensor!!
Anyone have an easy way to remove the stock Oxygen sensor. I can't seem to fit any tools down there to twist that sucker out! Help plz!
-nathan-
Old Aug 25, 2001 | 04:49 PM
TwinCam13BT's Avatar
Soak it with some WD40 or the likes. I just use an opened end fot that.
good luck
Old Aug 25, 2001 | 05:00 PM
Phungus's Avatar
I bought an oxygen sensor 1/2" socket from Pepboys. worked like a charm.
Old Aug 25, 2001 | 05:18 PM
khoney's Avatar
Just did it myself 10 minutes ago! I feel your pain! I couldn't get anything on the nut, but I was able to get a set of vice-grips on the top of it, coming in from the firewall side. I then had no torque, of course, so I stuck a large screwdriver in an open area in the vice-grips and used it to turn the vice-grips a bit. It then came loose easily (HUGE sigh of relief!). Good luck!
Old Mar 12, 2003 | 10:22 AM
xplikt's Avatar
DAMN THING!! The little bastard wont come off on mine. I just dumped some bolt penetrant on it and hopefully that will loosen it up and I can get it it tonight.
Old Mar 12, 2003 | 10:45 AM
Spawn VII's Avatar
that o2 sensor socket works like a charm... just stick it in, twist it, and done
Old Mar 12, 2003 | 10:47 AM
Rpeck's Avatar
What R U thinking self?
Start the car and heat up up good and hot. Then pop on your O2 socket, if you need to, use a few extentions and a impact gun.
Old Mar 12, 2003 | 11:01 AM
Turbonut's Avatar
I must ditto the above. Get car warm and use the O2 socket. You can break it loose, then if you want, remove it when cool. Works like a charm.
Old Mar 12, 2003 | 11:35 AM
littlejep's Avatar
It took me a couple of tries, they are right though, its worth buying the special socket to fit around the o2 sensor itself, it may also take you a few different extensions that have wobble arms on them so that you can get the right angle on it to really wrench it off of there. Good luck. O one last thing, when you put that new one on, make sure you put lots of anti-sieze on it so you can get it off easily in the future.
Chris
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
rotor_veux
Sep 19, 2015 07:13 PM
