Rubber Couplings
Old Apr 1, 2003 | 03:26 PM
HDP's Avatar
HDP
A Fistfull of Dollars!
Rubber Couplings
What are the diameters and lengths of the 3 short rubber couplings on the rear turbo inlet, y-pipe and intercooler? I want to order silicone replacements.
Old Apr 1, 2003 | 04:22 PM
93BlackFD's Avatar
built my own engine
the ones RX7store carries fit fine
although i wouldn't recommend replacing any except for the upper intercooler pipe
the y-pipe to crossover pipe will burst open
the silicone is made for clamping down two metal pipes, you can't clamp hard enough on plastic for it to work...they just blow apart
Old Apr 1, 2003 | 11:02 PM
gohorns's Avatar
2.75" x 3" is what I used, my coupling goes over the bump on the rear turbo inlet tube.
Old Apr 2, 2003 | 06:21 AM
HDP's Avatar
HDP
Thanks for the info. I guess I'll just reuse the OEM couplings.
Old Apr 2, 2003 | 08:15 AM
DamonB's Avatar
I have been using the 2.75" orange turbo hose from Baker Precision for a long time on each end of the crossover tube. Never had it come off or split. Highly recommended.
Think it's about $25 for one foot which will make 4 couplers.
Old Apr 2, 2003 | 09:14 AM
gohorns's Avatar
damon, do you know what the thickness is on those? 2.75 is the inside diameter, what does the outside measure?
Old Apr 2, 2003 | 09:42 AM
DamonB's Avatar
Its walls are maybe 1/8" thick? So that would give a 3" outer diameter. This particular silicone hose is heavily fiber reinforced. It's thinner than most other stuff but very, very tough.
turbo hose
Old Apr 2, 2003 | 09:46 AM
HDP's Avatar
HDP
2.75"x 3" for turbo inlet coupling, what about the other 2? They appear to be the same size.
Old Apr 2, 2003 | 10:38 AM
DamonB's Avatar
No. If I remember correctly the intake couplers to the airbox and turbo inlet are 3" inner diamter. The couplings to the y-pipe and intercooler are 2.75".
Old Apr 2, 2003 | 11:06 AM
HDP's Avatar
HDP
What about the one on the rear turbo inlet?
Old Apr 2, 2003 | 11:31 AM
DamonB's Avatar
That is considered an intake coupling. 3".
Old Apr 2, 2003 | 03:18 PM
Tom93R1's Avatar
gross polluter
That is what I use, the texture on the outside does a great job of keeping the clamp in place. I have had it about a year and have never had one slip of leak. I second this recommendation.
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
yr6
Oct 4, 2015 12:23 PM
Jetlag
Sep 29, 2015 06:52 AM
