? about turbo exhaust temps before the IC
Old Apr 1, 2003 | 02:52 PM
Brentis's Avatar
Does anyone know what the typical temps are coming out of the turbos but BEFORE the IC??
The reason I am wondering is that the bottom of my Greddy SMIC is exposed to the radiator "exhaust" and I was wondering if it would help heat soak if I but some thermal shielding on the bottom IC can.
Thanks for the help!
Old Apr 1, 2003 | 04:28 PM
Marshall's Avatar
Stock twins???
If so, 200-250 F at around 12 psi depending on inlet temp. 15 psi on a hot day and you're heading for 300!
Old Apr 1, 2003 | 04:35 PM
Know what you mean about heat soak. I was wondering if shielding the bottom of the intercooler would help, too.
Old Apr 1, 2003 | 04:38 PM
Brentis's Avatar
yea - stockers..
Old Apr 1, 2003 | 04:59 PM
ttb's Avatar
ttb
No Cup Holder Racing
Originally posted by Marshall
Stock twins???
nice to know...looks like my IC cuts the temp. in half.
Old Apr 1, 2003 | 07:26 PM
maxcooper's Avatar
WWFSMD
I have some aluminized fiberglass mat insulation under my SMIC. I have not idea if it helps or not, but it seemed like it might reduce heat soak at least.
-Max
Old Apr 1, 2003 | 09:43 PM
Brentis's Avatar
so my question is -- if the turbo air is hotter than the radiator air should one be concerned about the impact of the radiator on the lower part of the IC? Not talking about the fins, but the bottom/area exposed to rad.
FD7KiD
15
Feb 26, 2021 10:12 PM
sherff
Feb 24, 2019 12:09 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
FD7KiD
Aug 17, 2015 11:50 PM
