CSP SCCA -- what are your modifications?
Old Mar 22, 2003 | 02:34 PM
xplikt's Avatar
For anyone who is running C Street Prep, what modifications have you done to your vehicle only allowed in this class?
Old Mar 22, 2003 | 04:23 PM
Mld>7's Avatar
I Post Mad Quick Yo!
If you mean what can you do to your car and what cant you, check out the site. All the info is there
http://www.scca.com
Old Mar 22, 2003 | 07:28 PM
TheTwinTurboRX-7's Avatar
I run CSP
Racing Beat Springs
Tokiko Blue Shocks
Panasport 15x7 tires
Racing Beat Streetport Exhaust
Webber 45DCOE Carb
stripped engine
relocated battery
CP Racing Three Way strut bar
Falken Azenis 205/50/15's
I need a front bushing kit, larger front sway bar, and LSD and I will be extremely competitive. Right now I am only fairly.
Old Mar 22, 2003 | 07:44 PM
88IntegraLS's Avatar
Displacement > Boost
What class would porting the engine put you in?
Old Mar 22, 2003 | 08:08 PM
Wormiez's Avatar
I Run C/SP
Suspension:
K2rd Coilovers with AGX Shocks and Ground Control Coilovers
K2rd Camber Plates/Pilloball Mounts
K2rd Rear Camber Kit
Cusco Front Strut Bar
Cusco Rear Stur Bar
Cusco Lower Arm Bar
J's Racing Upperpillar bar soon to be replaced with a roll bar or cage.
Battery reollcated to the passenger rear
GTUS LSD
New Autoexe bushings all round
Racing Beat Toe Eliminator Bushing
And a street clutch
Soon to have: Racing Beat Sway bars and endlinks
Old Mar 22, 2003 | 08:23 PM
Porting would put you in SM2
porting and slicks puts you in just straight mod
Old Mar 22, 2003 | 08:53 PM
xplikt's Avatar
Mld>7, I should have been more clear, sorry. I meant I wanted to see what products and setups people are running in this class.
Right now I've only done a complete exhaust and headers. Next month or early May I was looking to get some Falken Azenis and maybe some new shocks. I figure that's probably my best bang for the buck in handling.
After those two changes, and another month or two, what should be my next step? Springs, struts, or sways?
Thanks for the replys.
Old Mar 26, 2003 | 11:45 PM
Wormiez's Avatar
I suggest get a full coilver system, and then swaybars.
Old Mar 28, 2003 | 10:57 AM
1st7heaven's Avatar
This actually puts you in a prepared class. I used to run CSP , coil overs, 13x9s, SE motor with a Dellorto, header, Jacobs ignition, roll bar, no rear swaybar, large front swaybar, camber plates, 4.11 rear end which is leagal(this is stock in the SE), alum. flywheel, oh yah btw I have an 84GSL.
BTW, the motor was a STOCK SE, 6port. You can only up date and back date in the same body style. In other words you cant put 86' and up goodies in the 1st gen body.
Old Mar 28, 2003 | 09:39 PM
Rx7carl's Avatar
Airflow is my life
alum FW is CSP legal? Hmmmmmmm.
oh xplikt get Hoosier A3SO3's if you want great dry tires. They are unforgiving, but dog *** fast.
Old Mar 28, 2003 | 11:33 PM
Originally posted by 1st7heaven
This actually puts you in a prepared class. I used to run CSP , no rear swaybar, large front swaybar,
Did you use that sway bar setup to keep the rear end planted when braking and turning? I am doing that same setup on my FC.
Old Mar 29, 2003 | 01:23 AM
gamble302's Avatar
roadkill hats rock
whoa porting doesnt put me in street mod? what class would i be in? 85 gs with street port 12a
and can you tell me off the top of your head what class im in after i put slicks on?
Old Mar 29, 2003 | 06:52 PM
Rx7carl's Avatar
Airflow is my life
Slicks are prepared and modified. Dont recall about porting although its past SP.
Old Mar 29, 2003 | 08:37 PM
gamble302's Avatar
roadkill hats rock
i havent been able to find anyone would tell me what class to run in so ive been cookin around under the sm2 name. still having fun, just wondering what class i should really be in
Old Mar 31, 2003 | 08:04 AM
gamble you know now
SM2 is correct man
and e or c prepared, I forget which with the slicks
Old Mar 31, 2003 | 10:13 AM
leatherseatcovers's Avatar
Ported engine and slicks will put you in FP, not sure about the SM2 stuff. Get a Solo Rule Book from the www.scca.org site and study it no matter what class you wnat to run.
Old Mar 31, 2003 | 12:15 PM
I just mooch off a friend
know my own class rules pretty good by now anywho
sm2 is ported with no slicks
Old Apr 1, 2003 | 11:49 AM
xplikt's Avatar
I didn't want to go to a full slick yet. The Falkens are at least still a street tire by SCCA classifications. I'll probably be buying a set of those later this month.
Old Apr 1, 2003 | 02:03 PM
frazer's Avatar
I successfully ran CS a few years ago, but that was at a local level. Won championships in DC Region SCCA and MWCSCC (another DC Region class). I started out in CSP, then sold my equipment and set it up for C Stock- to be competitive. I guess a 2nd gen could be semi-competitive at a local level in CSP, but no way Nationally. A properly set up CSP CRX, Civic, Miata, etc... will kick the sh*t out of the RX-7 all day long. Don't get me wrong, I love my '7, but... My recommendation: do it for fun, enjoy it, and learn to drive your car better. If you want to be famous and win (in any class), look at the Solo II Nats. results and buy a car that for sale that finished up front or buy a new one of the same model.
I ran Kumhos and loved them. IMHO, a set of DOT R-compound tires makes a huge difference!
Just my $.02.
Mike
RCF MotorSports
Old Apr 1, 2003 | 03:58 PM
xplikt's Avatar
Yeah, I am keeping this mostly to a local level. If I was looking to be real compeditive I would have bought a CRX.
Old Apr 1, 2003 | 04:24 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
street port and slicks = e prepared
bridge or peripheral port and slicks = f prepared
NickNac113
13
Oct 1, 2015 09:25 PM
Turblown
Sep 30, 2015 05:58 PM
