door locks messed up
Old Mar 21, 2003 | 10:27 PM
hornbm's Avatar
FD > FB > FC
hey i made the discovery that any straight object will turn my door locks. it just has to turn the lip on the end of the lock and the whole thing turns.
This is happeneing on both the driver side and the passenger side.
Has this happnened to anyone before? More importantly how the hell would I go about fixing it?
Old Mar 21, 2003 | 10:31 PM
Well, getting new locks would work!
But, maybe the inside is gummed up at it thinks there is a key in there. Other than that, I have no idea????
Old Mar 22, 2003 | 12:08 AM
probably just worn out... that seems common (in my experience) with older locks...
or as Rotary rev. suggested maybe it's just a little dirty / sticky in there
Old Mar 22, 2003 | 01:56 AM
Keaponlaffen's Avatar
is it the whole lock body that's turning? 'cause that's a completely different story....
if just the chamber inside is turning, then that's probably just 'cause it's REALLY worn out... but if everything's turning, including the chrome surround on the lock body, then it's because the spring plate in the back has fallen out and is allowing everything to turn at once...
Old Mar 22, 2003 | 07:46 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Re: door locks messed up
On my 80, I could lock unlock my doors with ANY mazda key, the tumblers in the locks were so wore out... I think it might be time for a new key set man
Old Mar 23, 2003 | 07:01 PM
hornbm's Avatar
FD > FB > FC
yeah u can unlock it with any straight object. How much would new locks cost me?
Old Mar 23, 2003 | 07:11 PM
gsl-se addict's Avatar
Super Moderator
Yeah, I too am experiencing this problem with my driver side door. I am also able to pull the key out of the ignition, while the car is running. You can get locks through Mazdatrix. The whole set with the column lock is $323. They also have individual door locks for around $50 a piece.
Kent
sherff
Sep 12, 2015 12:22 PM
TwentyDW
Sep 2, 2015 06:42 PM
