Need Help: general 93-95 RX7 Buildup
Old Mar 21, 2003 | 05:10 PM
Ryan Autry's Avatar
Looking to get a 93-95 RX7 in the near future.
So I've been doing a little research. I did this buildup and got all the prices from www.rx7.com
I never thought of buying one until I sat in my friends the other day. I couldn't believe I fit (6'6" 280)
So that same day I did a little research.
My friends RX7:
I'd like to have 400whp on pump if possible. I did a little buildup. I don't really want to spend more then $15,000 on modifications.
If and when I buy one I will throw in a new engine with upgraded apex seals. I'd also love the HKS T51 Turbo upgrade, but it's out of my budget.
With this buildup.
What am I missing?
What is not needed?
What should I change?
What do you guys recommend?
Brakes $799
BR400322
Bönez Stage (I) Brake Upgrade (Slotted Rotors)(SS Lines)(Pads)
$799
Clutch / Drivetrain $2,000
CL500152
Bönez Street-Comp Clutch
$500
CL500533
RP Braided Stainless Steel Clutch Hose (93-95)
$38.00
CL500104
Bearing Kit (Release bearing, Pilot Bearing and seal)
$69
CL500119
Clutch Alignment Tool
$3
CL500343
Bönez Billet Aluminum Flywheel
$499
CL500852
KAAZ 1.5way LSD
$880
Cooling System $785
EN650133
Koyo Aluminum Radiator (5sp only)
$499
EN650140
Aluminum air separator tank
$150
EN650163
Genuine Mazda upper and lower radiator hose set
$38
EN650164
Genuine Mazda water pump w/gasket
$85
EN650155
Mazda genuine thermostat (93-95 rx7)
$12
Engine Parts $350
EN600136
RP Triple Race Pulley Kit
$350
Exhaust $1,070
EX810738
Bönez Racing 3' Stainless Steel Downpipe
$345
EX810733
Bönez Racing Center Pipe (Stainless Steel)
$235
A'pex N1 Racing Cat-Back
Part # EX310404
$490
Exterior Parts $190
'99 Spec Front Lower Lip
$190
Fuel System Upgrades $3,395
FL900324
RP FD secondary rail and 1600cc injector kit w/ SX regulator and competition pump
$995
FL400010
Apex'i Power FC ECU
$980
FL400012
Power FC commander
$350
Intake $129
IN200296
C-west Fresh Air Headlight Cover
$129
Suspension $745
SUILK516
Tokico Advanced Handling Kit
$745
Turbo Parts $6,245
TR375001
GReddy 2000 Black Turbo Timer
$90
TR374000
GReddy Profec Boost Controller
$535
TR15500351
GReddy Profec Remote Switch
$115
TR370101
GReddy Blow Off Valve (Type-R Standard Spring)
$229
TR370111
GReddy Aluminum Flange for Blow Off Valve
$31
TR353257
GReddy NEW Polished Front Mount Intercooler 2 row R-SPL Core (Single Turbo)
$1265
TR323820
GReddy BIG Turbo Upgrade Kit (T78 33D-17cm)
$3980
Total $14,700
Old Mar 21, 2003 | 05:14 PM
meddle's Avatar
Umm sounds pretty comprehensive.
Old Mar 21, 2003 | 05:15 PM
curlybillbrosie's Avatar
no intake?
Old Mar 21, 2003 | 05:17 PM
DomFD3S's Avatar
Mod Powers...gone!
Actually, I would suggest going to the Single Turbo section of this forum. A number of those guys have modifications which will support the amount of power you want from your car.
Ryan Autry's Avatar
Originally posted by curlybillbrosie
no intake?
Did I forget that? Sorry.
I thought the GReddy turbo kit came with one?
Old Mar 21, 2003 | 05:34 PM
Ryan Autry's Avatar
Thanks, I'll try there.
Old Mar 21, 2003 | 05:41 PM
paw140's Avatar
I don't see a new engine on your price list? Also, I just happen to notice that your numbers for the fuel system don't add up to your total. I think you're a grand off there.
You might want to consider having BNR upgrade your stock twins instead of going single. That will save you a lot of money, and you can still reach your power goal.
Old Mar 21, 2003 | 05:53 PM
Ryan Autry's Avatar
New engine will be the first thing I do. But I don't consider that a modification. I consider that maintainence.
nice catch on the price.
i will look into the BNR upgrade.
Thanks
Old Mar 21, 2003 | 06:09 PM
Oh.....I dont know. If it does, rock on.
Old Mar 21, 2003 | 10:07 PM
Trout2's Avatar
I caught a few things. You don't need the downpipe, that comes with the T78 kit. Count on an ignition upgrade for this power level (Jacobs, HKS, MSD, Crane, etc.) Along with replacing the radiator hoses, count on replacing the other heater/coolant hoses. I assume you're installing this yourself because there's no labor in your estimate. To make all those parts work right together you need to budget some money for tuning. Whatever estimate you come up, add another $1-2000 for unexpected expenses.
400whp is easily obtained on pump gas with a T78. I would suggest riding in some other Rx7's with different turbos to get a feel for the power delivery. There are other turbos that would suffer less lag and still make this hp.
Jack
Old Mar 21, 2003 | 11:20 PM
ttb's Avatar
ttb
No Cup Holder Racing
how about some wheels and tires to get that power down...add another 3k
Old Mar 22, 2003 | 12:14 AM
Ryan Autry's Avatar
Jack
Thanks for looking out. . .
So the Stock Ignition won't handle 400?
I will be doing all the work. And tuning if I can with a wideband on the street.
Can the Apex not be tunned on the street?
I wish I could take a ride in a few RX7's. But I only know one person with one.
I'm sure when I do actually buy the car I will ask some people on here for a ride.
Thanks for the reply
Ryan Autry's Avatar
Yes, Wheel and tires will be added. But I don't add that into my performance budget.
Old Mar 22, 2003 | 12:28 AM
ttb's Avatar
ttb
if you're going to tune it yourself add the datalog (299)...you don't need the commander...plus get a laptop for 2-3k
Old Mar 22, 2003 | 12:29 AM
BOOSTMiesterGeneral's Avatar
Thats pretty blatant would you say?
Old Mar 22, 2003 | 01:15 AM
Ryan Autry's Avatar
So I don't need the Commander, just add datalogging?
I already have the laptop. I have Engine Management in my current car.
Old Mar 22, 2003 | 01:20 AM
ttb's Avatar
ttb
yup, if you're trying to save money you can skip the commander and just get the datalog software. it does everything the commander does and a little more.
Old Mar 22, 2003 | 11:51 AM
Trout2's Avatar
You'll need something for ignition, when you start running 13psi or more you'll get ignition break up at high rpm. Typically some kind of ignition amp and different heat range plugs.
If you have a wideband and Datalogit, you can tune on the street. Street tuning is actually prefered since you're in real world conditions but I would still take it to a reputable Rx7 tuner in the end for fine tuning. As you will fiond in research the Power FC has numerous correction maps and timing is the black art of rotary tuning. Some info is shared on timing here if you search but its not nearly as straight forward as fuel.
If you don't get the Commander then budget for some gauges to monitor engine parameters. I think the Commander is worth the cost just for the monitor functions and troubleshooting assistance. If planning to tune yourself, invest in an accurate EGT guage.
As for riding in other 7's, look in the regional forum to see if there are any local Rx7 meets where you might meet owners with different setups. There are a lot of nicely modded Rx7's in CA.
I agree on the wheels and tires. I'd consider a little more budget for suspension. Like a set of adjustable coil overs. These cars wheel hop violently when launching from a dead or slow roll. Looks into Unobtainium differential and suspension bushings plus solid joint lower control arms and toe links for the rear.
I'd say get the car first and make sure all systems function correctly then mod it slowly so you can enjoy the small increases in power and make things easier to trouble shoot if there's a problem.
Jack
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
