Clutch fan help
Old Mar 19, 2003 | 02:41 AM
browney's Avatar
Clutch fan help
Hi,
The clutch on this fan isn't working properly so I want to replace whole thing with the fan out of my other rx-7. Where do I unbolt it to take the fan with clutch out, red or blue. Thanks.
Old Mar 19, 2003 | 02:58 AM
680RWHP12A's Avatar
red, if you unbolt the blue , the fan still wont come off
Old Mar 19, 2003 | 03:08 AM
browney's Avatar
o.k thanks, That is what I thought. The only problem is when I try to unbolt it the whole assembly just spins and I cant turn the bolts , I guess I will have to get out the wd40 and find some way of bracing it so only the bolt turns. Also I got told that It wrecks the clutch if you lie the fan flat is this true?
Old Mar 19, 2003 | 06:40 AM
esoto66's Avatar
Originally posted by browney
find some way of bracing it so only the bolt turns. [/B]
Hold with screwdriver...........good luck.
Old Mar 19, 2003 | 06:56 AM
85RX7GS's Avatar
The red bolts should come right out if you hold the alternator or A/C pulley while applying pressure to the wrench. If not, take a pipe wrench and put it around the alternator pulley. While holding the pipe wrench steady, take your 10mm wrench and remove the red bolts.
Old Mar 19, 2003 | 08:09 AM
RacerX7fb's Avatar
paradox
To help make it easier.. unbolt the fan shroud as well and remove/install it back at one time
Old Mar 19, 2003 | 08:17 AM
jeremy's Avatar
male stripper
to make it easier, throw into garbage and purchase elec fan.
Old Mar 20, 2003 | 12:26 AM
browney's Avatar
hmm, when i turn the bolts and the assembly turns the alternator doesn't (the belt just slips) but my alt does work when I am driving.
Old Mar 20, 2003 | 09:13 AM
cveklund's Avatar
Put a pair of vice grips on the part between the red and blue bolts. Thats what I did when removing the rat's nest(thanks pratch and RX7Carl).
Chris
Old Mar 20, 2003 | 09:48 AM
Cloud's Avatar
Boing
word.
Old Mar 20, 2003 | 12:46 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
NO!
That has to be one of the funniest things I've heard. Do you think that those fan clutches come all the way from Japan and are never laid down flat when they're new in the box? -WG
Blastfastrotary
Sep 11, 2015 12:26 AM
risingsunroof82
Sep 9, 2015 08:06 PM
