Hubs?
Old Mar 18, 2003 | 09:01 AM
mzspeed7's Avatar
Question Hubs?
Can you replace the bearing in the pass. rear hub? B/C I went to mazda and they said that you could not replace the bearing in the rear hub. They said that you have to replace the whole thing. If you can replace it how do you replace it.
Old Mar 18, 2003 | 11:08 AM
hIGGI's Avatar
sure u can, u`ll need press for it..
Old Mar 18, 2003 | 11:19 AM
Turbonut's Avatar
See PM
Old Mar 21, 2003 | 11:14 AM
mzspeed7's Avatar
thanks man!
Old Mar 21, 2003 | 12:31 PM
HAILERS's Avatar
HAILERS
That's why Mazdatrix sells........rear wheel bearings. Done did it on two cars.
Old Mar 21, 2003 | 01:13 PM
snerd's Avatar
Do you have to grind notches in the hub (the same way that you do on the fronts) to be able to get the original bearings out?
http://www.mazdatrix.com/faq/frontbrg.htm
Old Mar 21, 2003 | 03:09 PM
Turbonut's Avatar
No notches. Sealed bearing. Press out.
Old Mar 26, 2003 | 12:06 PM
mzspeed7's Avatar
Can you give me a link where I can find rear bearings on Mazdatrix? B/C i could not find rear bearings on the site, all i could find was front bearings.
Old Mar 26, 2003 | 12:27 PM
Turbonut's Avatar
I purchased my bearings and seals from local parts store. The same one that pressed out the bearings.
Check with thw people where your going to have them pressed out. It's a lot easier to have them order the bearings/seals and do the install, then taking parts in from another supplier.
That is unless you have a press.
Old Mar 26, 2003 | 12:58 PM
Cheers!'s Avatar
Former Rx7 *****
the mazdatrix instructions are for front hubs and front bearings only.
Yes you can get rear bearings from mazda... the parts guy told me nope... u need new bearings... so i said fine...
i looked up the exact part number... called him back and he said... oh .
as for installng them... i have no idea... i'm going to find a shop to press out the breaings and press new ones in
Old Mar 26, 2003 | 02:33 PM
HAILERS's Avatar
HAILERS
****Can you give me a link where I can find rear bearings on Mazdatrix******
OOOps. No bearings there. Must have been Victoria British or Steve's Foreign Auto Parts on Vickery in Ft Worth. Sorry 'bout that misinfo. Buuuuut....I bet if you called them they'd sell you some rear bearings (Mazdatrix).
