have to wedge afm open to start started...
Old Mar 17, 2003 | 04:30 PM
RXtion Turbo II's Avatar
i posted a few days ago that my car would start up then cut off. some1 suggested to me that i poke open the afm and viola it starts up and idles. i used a rubber hose cut to the diameter of the afm opening to wedge the plunger open just a crack at all times so i could drive it around. this works fine except at partial throttle the car is rather jumpy. i can mess around with the hose sometimes to make it drive a little better but im constantly pushing the hose closer or farther in the afm and adjusting my idle. what can i do to fix this mess?? thanks in advance.
Old Mar 17, 2003 | 04:42 PM
gz91rx7's Avatar
HUMMM................I think you mean "get started?!"
Old Mar 17, 2003 | 04:51 PM
Pinfield357's Avatar
you could always just get another AFM if you think thats the problem
Old Mar 17, 2003 | 05:03 PM
the afm seems to work, its just not pulling back enough to allow the car to stay running. could a small vac leak do this? the idle doesnt bounce however....
Old Mar 17, 2003 | 06:46 PM
Aaron Cake's Avatar
Engine, Not Motor
Replace the AFM if you don't have any huge cracks in your intake tube.
Old Mar 18, 2003 | 02:10 AM
NZConvertible's Avatar
I'm a boost creep...
The fuel pump safety switch in the AFM is broken. Its purpose is to shut the fuel pump off in the event of an accident (engine stalls, ignition on). This stops fuel being pumped out of broken fuel lines, which is not a good thing... If the switch doesn't close when the AFM flap opens, the pump won't run.
There's a 2-pin yellow plug beside the RHS strut tower. Jumpering this plug bypasses the switch in the AFM so you can check the pump without running the engine. Doing this will get you mobile without your dodgy sounding rubber hose. You should only do this as a temporary measure! Get the AFM fixed or replace it.
Old Mar 18, 2003 | 07:42 AM
Josepi's Avatar
Despise Enmity
I'll have a S5 TII AFM up for sale in 2-3 weeks...
Old Mar 18, 2003 | 08:27 AM
SonicRaT's Avatar
Super Raterhater
I'm more willing to bet it's a vac leak.
Old Mar 18, 2003 | 08:37 AM
Node's Avatar
You have any tar like substance in your airbox or AFM? I had it all over mine, ended up being hte rubber gasket on the filter that had melted or something and gummed up everything, i ended up replacing the airbox filter and afm with a set from a junkyard for $17
P.S. My car would idle like ****, and/or die if you didnt keep it reved up before it got warmed up (probably made the tarlikeshit a lot less solid)
alphawolff
Nov 17, 2015 05:57 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
