intercooler
Old Mar 16, 2003 | 08:43 PM
VFactor24's Avatar
intercooler
Im just wondering if it would be safe to use the stock ecu with a PFS intake, dp, exhaust and an PFS intercooler. Im thinking as long as the boost is OK then i should be fine right?
Old Mar 16, 2003 | 08:48 PM
Mahjik's Avatar
Mr. Links
As long as you can control the boost and keep it at stock levels, tests have shown that you should be ok.
Old Mar 16, 2003 | 08:49 PM
nmo93's Avatar
as long as you keep the boost at 10 psi, whether w/ the home depot boost controller or an electronic boost controller you will be fine.
nick
Old Mar 16, 2003 | 08:53 PM
VFactor24's Avatar
yea right now i have a profec b, im just thinking about doing this set up temporarily until i can find a used petit unlimited ecu
Old Mar 17, 2003 | 12:54 AM
BoostedRex's Avatar
NorCal 7's Co-founder
You should be safe. Not to be rude, but I wouldn't waste your money on a reprogrammed ECU like the Pettit unlimited or the M2 unit. If you're gonna do it you'll be happier in the long run using a stand alone like the Power FC or the Haltech system. I've seen that scenario play out way way too many times. Just my .02
Zach
Old Mar 17, 2003 | 02:40 AM
damian's Avatar
DDH Motorsports
Top Answer: 1
yeah, what zach said :-)
Old Mar 17, 2003 | 03:00 AM
BoostedRex's Avatar
Thanx for the backing Damian. Good to know that someone out there agrees with me.
Old Mar 17, 2003 | 03:12 AM
Richierich's Avatar
crazy canuck
I still would not drive it hard in the slightest....get anything, even a f-con, youll be sorry if you don't!
I know people who have poped their engine at 9 psi
who did the same thing.......first fuel computer, THEN other mods.
mmmmmm.......
new engine $5000
fuel computer $1200
easy math.....are u a gambler?
just my 2 cents.
Old Mar 17, 2003 | 04:02 AM
1FooknTiteFD's Avatar
Ghost Ride the Whip
Does haltech work with sequential twins?
Either way you should get an ECU after 2 mods, and after the 3rd mod you should also consider doing an upgraded fuel pump as well. RX7's have been known to blow up pretty easily even with very few mods, you should play it safe
Old Mar 17, 2003 | 04:07 AM
T88NosRx7's Avatar
You'll be fine, just maintain your car.
Old Mar 17, 2003 | 04:56 AM
BoostedRex's Avatar
I believe that the E6K will work with sequential twins yes. I'm not 100% sure, but about98%. Either way, with what BNR is doing there's no reason not to run non-seq. But that's just my .02 Doesn't make it right. But to add on to what's been said about the original question, yes you should be ok but be very very safe when you drive. Replacing engines gets expensive really quick. Laterz.
Zach
ls1swap
Jun 3, 2024 03:25 PM
1NSIGHT
Sep 25, 2015 12:59 PM
MILOS7
Sep 18, 2015 03:39 PM
