how do i get rid of the smell?
Old Mar 16, 2003 | 11:35 AM
rx_7_driver's Avatar
Question how do i get rid of the smell?
simple question,
put vent on, no smell. Put heater on, no smell. Put A/C on with recylcer realy bad mildew (sp?) smell. what is it? kinda smells like a realy old car after its been sitting for awhile. its been about 4-5 months since i used the a/c so i have no clue when it started. any idea why it smells? how to get rid of it? and how to prevent it from happing agian?
-Shawn
Old Mar 16, 2003 | 11:55 AM
2a+RoN's Avatar
i'm not sure what exactly is stinking your car up, but when I bought my car, the previous owner was a really bad smoker and everytime I turned the ac on it smelled horrid. I used this stuff called ozium which works really well (i think it has ozone in it so it kills bacteria and stuff). Just spray it in the vents and it should give your car a spring fresh scent
Old Mar 16, 2003 | 12:02 PM
well i do smoke in my car but i always put both windows down (r the top) when i do, and its more like a mildew smell, and its only with the a/c on so i have no clue what is making it reek, i also tried numrous air fresherners (sp?) which only seem to work for a breef period of time then the smell fades away, and the mildew smell returns
-Shawn
Old Mar 16, 2003 | 03:13 PM
WTF
maybe you have a dead animal that crawled in your vents
Old Mar 16, 2003 | 03:30 PM
88 SE's Avatar
Try turning the AC off before you stop the car, like a block away. That should give any built up moisture time to evaporate and drain.
Old Mar 16, 2003 | 11:44 PM
where is the drain hole for the a/c? i am now thinking it is clogged
-Shawn
Old Mar 17, 2003 | 02:48 PM
Turbonut's Avatar
That's odd, 'cause a/c comes through the same duct work as vented air. On my wife's car, with the fan running, I sprayed Lysol into the air intake. Did it a couple of times...No problems. They do make something specifically for auto a/c systems, but sorry, don't know the name.
FYI-When hot humid, if you see condensation on ground, drain is open.
Old Mar 17, 2003 | 02:55 PM
well i thats it i don't see any on the ground, and sometimes when i turn the a/c off then back on a couple of min. later mist come out the vents.
-Shawn (post #700)
Old Mar 17, 2003 | 04:03 PM
KiyoKix's Avatar
13B N/A POWA!
Most likely you have a nasty buildup (moisture in the system) in the Receiver/Dryer unit on the car. You should take the car to a shop that can properly evacuate the system and then purge all the moisture out of it. Then of course recharge the system. Too bad you're not here, we could do it for free (college...w/all the tools and machines ).
Old Mar 17, 2003 | 06:51 PM
Aaron Cake's Avatar
Engine, Not Motor
That makes no sense. The A/C system is closed, and any moisture in the receiver/dryer unit (or compressor, or evaporator, or orifice tube, etc.) would never reach the atmosphere.
Try sprays like "smoke away" and the like. Put A/C on full, then spray into the air intake near the heater core. Empty the whole damn can. Worked for me.
Old Mar 17, 2003 | 07:59 PM
RaginRX's Avatar
Hey, the smell is coming from your condensor, which is located near your blower fan most likely, its prolly got some build up or mold growing on it, remove your blower fan and check it out
Old May 2, 2003 | 01:15 PM
xfeastonarsex's Avatar
fire from MY tailpipe!
My brother had an old jetta that would smell like car pee whenever we started the a/c then frost would shoot out the vent. We sprayed lysol in it and it seemed to get rid of the problem.
ls1swap
Jun 3, 2024 03:25 PM
renjiv2
57
Jan 25, 2024 03:34 AM
Aramir
Oct 18, 2015 02:39 AM
