4.5k idle!!
Old Mar 16, 2003 | 02:52 AM
Flying Monkey's Avatar
Question 4.5k idle!!
I'm a TII guy, but ran across a guy down the road from my father that had 2 1st Gen's sitting outside today. He was working on his 85 (I believe) that he dropped a 13B into before it got cold. Anyway, I stopped in to talk to him & his car is idling at 4-5k. It appears to have the throttle linkage completely removed, intake tract intact. Starts right up, but shoots to 4k, then slowly up to 4.5-5k. I pulled the intake right before the TB to see if the plates were stuck open. They appear to be closed. I'm at a loss. Thought timing, but 4.5k?? He's not very mechanically inclined, but is all for diving into the learning process. I guess I get to learn about 1st gen's now, too. I just downloaded the 85 FSM & I'll look through it, but I need some direction here. Any help is appreciated.
Old Mar 16, 2003 | 02:57 AM
ioTus's Avatar
'84 5-letter
check the green vacumn solenoid for leaks or brokenness.
Old Mar 16, 2003 | 04:57 AM
Will do. What is it called? I'm glancing over the FSM & haven't run across ay colors yet. I've got the 87 FSM nearly memorized, but this is the first tme I've checked out the 85. Seems to be ordered the same, going over section 4B now. Thanks for the help.
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
93FD510
Oct 1, 2015 02:00 PM
Jmpabon93
Sep 30, 2015 04:57 PM
